E30 M30B34 Swap (or 5/6/7 series engine/transmission replacement)
Means of contact: PM/Text-Call/Email: Here/7573384564/rccuffee@vt.edu (txting is best)
Price: 1500$
Description:
I have a complete swap for the e30. this includes:
engine: m30b34 from guten parts service:
new custom e30 mounts
new rear main seal
new thermostat
new cam oiling bar bolts and crush washers
new "duck" gasket for the rear of the head
new oilpan gasket
new waterpump and gasket
new intake manifold gaskets
new oil filter and gasket
new vc gasket
new tb gasket(no installed yet)
new bosch ign rotor
new rad hoses, upper and lower e34
E28 radiator
b35 intake mani
b35 thermostat housing
e34 pan/pump
dist cap
b35 starter
b35 exhaust manifold
e34 down pipes
x-y pipe
G260 transmission
m5 clutch/pp
535i flywheel
535i slave cyl
new pilot bearing
all new transmission bolts
new clutch slave
179 dme
Pictures:
Only thing you need is engine/trans bushings (i was gonna use poly) and finish exhaust. if you have a 5spd m20, you can reuse the transmission crossmember, hydrolic lines and driveshaft. You can also use the harness just extend some wires. All sensors on the m30 have been converted to e30 type.
ILOVEVAGINA -- If this line is still here it means you probably filled out the required information correctly and a mod will be looking at your thread shortly.
Price: 1500$
Description:
new rear main seal
new thermostat
new oilpan gasket
new vc gasket
new bosch ign rotor
E28 radiator
b35 intake mani
e34 pan/pump
dist cap
b35 starter
e34 down pipes
x-y pipe
G260 transmission
m5 clutch/pp
535i flywheel
535i slave cyl
new pilot bearing
new clutch slave
179 dme
Pictures:
1beatupteggy
Engine / Exhaust / Drivetrain
07-09-2009 01:31 PM
