Complete 4G63 Fully built Race Motor, Turbo, Fuel Setup. Throttle Body to 02 Housing.
Location: Fredericksburg Means of contact: PM or email (sean.k.bailey@gmail.com) Price: $8000 Description: I gotta say this really sucks. I was so close to finishing this car. I have spent a total of around $12,000 on this entire setup with all the machining, specialty work and parts. But my wifes business is tittering on failure and our house is on the business so we need money fast. This engine hasn't even been started yet. It has 0 miles on it. It has been primed to check for leaks and it does not have any leaks. All that's left to do is put a timing belt on it Here is what the engine has. THE MOTOR WILL COME 100% COMPLETE READY TO BOLT IN!!!! The price includes everything including the twin in-take fuel system and DSMLink with a runable idle fuel map. Head Stage 2 Port & Polish by Strictly Import Motorsports Fidanza Adjustable Cam Gears 272/272 Kelford Camshafts 3mm Revised Lifters Manley Dual Valve Springs Manley Titanum Retainers Ferrea Bronze / Manganese Intake Valve Guides Ferrea Copper Alloy Exhaust Valve Guides Stainless Steel Swirl Valves New Valve Seals Stock Rockers, Valve Locks In-betweeners Fel-Pro PermaTorqueMLS Head Gasket MAP Ultimate Duty H11 Head Studs Gates Timing Belt Bottom End The Entire rotating assembly has been balanced and blue printed. The bottom end MACHINE WORK cost me $1600 alone. Manley 8.5:1 Forged Pistons (86mm) Manley H-beam Cononection Rods ARP Rod Bolts Kings Rod Bearings (0.010”) Kings Main Bearins (0.010”) ARP Main Studs NEW Oil front case NEW OEM 90 Oil filter Housing NEW Air to Air Oil Cooler with braided nylon lines. Intake Side Custom 4" Intake Holset H1E (HX-40) Turbo. N/T 60mm Throttle Body JM Fab street SMIM Exhaust Side ARP SS Exhaust Manifold Stud & Nut Kit HAFE Exhaust Manifld (Thermal Coated) BEP Bolt-on Turbine housing (AR .55) (Thermal Coated) ARP Chromoly Turbo Bolts Punishment Racing Tubular 02 housing for 38 mm Wastegate, recirculated. (Thermal Coated) Tial 38mm External Wategate (Thermal Coated) Go-go Juice Full Blown 1g DSM Dual Walbro Kit -6 AN Fuel Feed Line from tank-filter-rail. Fuel Lab Fuel Filter Aeromotive Fuel Rail FIC 1050cc Injectors Aermotive A1000-6 Adjustable Fuel Pressure Regulator Misc/Dressup Prothane Motor Mounts Sight Glass Clear Cam Cover SS Oil pan bolts SS Valve Cover Bolts. Pictures. https://farm7.static.flickr.com/6145...9022d5a9_z.jpg https://farm7.static.flickr.com/6025...ae916e4c_z.jpg https://farm7.static.flickr.com/6141...03ac38cc_z.jpg https://farm7.static.flickr.com/6121...87be591e_z.jpg https://farm7.static.flickr.com/6142...99b5042b_z.jpghttps://farm7.static.flickr.com/6007...6e84bbc3_z.jpg https://farm7.static.flickr.com/6025...429a29d1_z.jpg https://farm7.static.flickr.com/6010...941dbd33_z.jpg https://farm7.static.flickr.com/6126...f44b98e4_z.jpg https://farm7.static.flickr.com/6012...69b3c6dc_z.jpg https://farm7.static.flickr.com/6015...c4a21b17_z.jpg https://farm7.static.flickr.com/6135...a4df1d98_z.jpg https://farm7.static.flickr.com/6149...08f9b012_z.jpg https://farm7.static.flickr.com/6018...c15030d6_z.jpg https://farm7.static.flickr.com/6006...a42eabfa_z.jpg https://farm7.static.flickr.com/6145...d8b7f291_z.jpg https://farm7.static.flickr.com/6009...71cf6ce6_z.jpg https://farm7.static.flickr.com/6007...7e015e01_z.jpg https://farm7.static.flickr.com/6128...3245c483_z.jpg https://farm7.static.flickr.com/6001...e1a24664_z.jpg https://farm7.static.flickr.com/6133...6dfdb68c_z.jpg https://farm7.static.flickr.com/6143...58300f0c_z.jpg https://farm7.static.flickr.com/6149...04f8d55d_z.jpg http://a5.sphotos.ak.fbcdn.net/hphot...6_290187_n.jpg https://farm7.static.flickr.com/6182...0225822d_z.jpg https://farm7.static.flickr.com/6076...0fb06558_z.jpg |
Re: Complete 4G63 Fully built Race Motor, Turbo, Fuel Setup. Throttle Body to 02 Hous
hate to hear wat ur going thru man. but bump for some good pics
Thanx for the bump. It is what it is. If I'm lucky, I'll come back in the summer.
buuuuuuuuuuump
bump for some super clean shit!! hope you get out of that hole bro..
Damn sorry to hear this, GLWS lmk if you wanna part ways with that intake manifold and throttle body
Bump for sad man.
Its Friday.
