Complete 4G63 Fully built Race Motor, Turbo, Fuel Setup. Throttle Body to 02 Housing.
Old 09-16-2011, 08:48 AM
laserspeeddemon's Avatar
laserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these partslaserspeeddemon is infamous around these parts
Unhappy Complete 4G63 Fully built Race Motor, Turbo, Fuel Setup. Throttle Body to 02 Housing.
Means of contact: PM or email (sean.k.bailey@gmail.com)
Price: $8000
Description:
I gotta say this really sucks. I was so close to finishing this car. I have spent a total of around $12,000 on this entire setup with all the machining, specialty work and parts. But my wifes business is tittering on failure and our house is on the business so we need money fast. This engine hasn't even been started yet. It has 0 miles on it. It has been primed to check for leaks and it does not have any leaks. All that's left to do is put a timing belt on it
Here is what the engine has. THE MOTOR WILL COME 100% COMPLETE READY TO BOLT IN!!!! The price includes everything including the twin in-take fuel system and DSMLink with a runable idle fuel map.
Head
Stage 2 Port & Polish by Strictly Import Motorsports
Fidanza Adjustable Cam Gears
272/272 Kelford Camshafts
3mm Revised Lifters
Manley Dual Valve Springs
Manley Titanum Retainers
Ferrea Bronze / Manganese Intake Valve Guides
Ferrea Copper Alloy Exhaust Valve Guides
Stainless Steel Swirl Valves
New Valve Seals
Stock Rockers, Valve Locks
In-betweeners
Fel-Pro PermaTorqueMLS Head Gasket
MAP Ultimate Duty H11 Head Studs
Gates Timing Belt
Bottom End
The Entire rotating assembly has been balanced and blue printed.
The bottom end MACHINE WORK cost me $1600 alone.
Manley 8.5:1 Forged Pistons (86mm)
Manley H-beam Cononection Rods
ARP Rod Bolts
Kings Rod Bearings (0.010”)
Kings Main Bearins (0.010”)
ARP Main Studs
NEW Oil front case
NEW OEM 90 Oil filter Housing
NEW Air to Air Oil Cooler with braided nylon lines.
Intake Side
Custom 4" Intake
Holset H1E (HX-40) Turbo.
N/T 60mm Throttle Body
JM Fab street SMIM
Exhaust Side
ARP SS Exhaust Manifold Stud & Nut Kit
HAFE Exhaust Manifld (Thermal Coated)
BEP Bolt-on Turbine housing (AR .55) (Thermal Coated)
ARP Chromoly Turbo Bolts
Punishment Racing Tubular 02 housing for 38 mm Wastegate, recirculated. (Thermal Coated)
Tial 38mm External Wategate (Thermal Coated)
Go-go Juice
Full Blown 1g DSM Dual Walbro Kit
-6 AN Fuel Feed Line from tank-filter-rail.
Fuel Lab Fuel Filter
Aeromotive Fuel Rail
FIC 1050cc Injectors
Aermotive A1000-6 Adjustable Fuel Pressure Regulator
Misc/Dressup
Prothane Motor Mounts
Sight Glass Clear Cam Cover
SS Oil pan bolts
SS Valve Cover Bolts.
Pictures.
laserspeeddemon is offline
Old 09-16-2011, 08:16 PM
V6 POWERED CIVIC
ILOVEHATERS's Avatar
ILOVEHATERS has disabled reputation
Default Re: Complete 4G63 Fully built Race Motor, Turbo, Fuel Setup. Throttle Body to 02 Hous
hate to hear wat ur going thru man. but bump for some good pics
ILOVEHATERS is offline
Old 09-17-2011, 06:41 PM
Thanx for the bump. It is what it is. If I'm lucky, I'll come back in the summer.
Old 09-19-2011, 09:34 AM
Old 09-23-2011, 01:53 AM
Old 09-24-2011, 05:20 PM
buuuuuuuuuuump
Old 09-24-2011, 06:51 PM
tattooman01's Avatar
tattooman01 has disabled reputation
bump for some super clean shit!! hope you get out of that hole bro..
tattooman01 is offline
Old 09-28-2011, 06:52 AM
Eat A Dick
Riff Raff's Avatar
Damn sorry to hear this, GLWS lmk if you wanna part ways with that intake manifold and throttle body
Riff Raff is offline
Old 09-29-2011, 10:55 AM
Bump for sad man.
Old 09-30-2011, 05:46 AM
Its Friday.
