Built SR20DET BLOCK!MSC SR/KA PARTS! BIG TURBO!
Jalil Hamilton
Fairfax Virginia
571-235-9681
jahlil2nyc@gmail.com
jahlil2nyc@yahoo.com
Fresh S20DET BOTTOM END
Will come with machine shope balance and blue print sheet 87mm..Bore..
All ARP hardware
New Stock Piston with Factor heat coating
ER sportsman Rods
clevite bearings
Polished /crank and balanced rotating assembly
This Was Hybridynamics spare race block that set the highest horsepower numbers with everything is upgraded to there specs ...500+
$2000 OBO
New Custom Borgwarner S256 Turbo with extended tip technology this was made custom to bolt on to stock cast sr20det manifold or aftermarket T2 based manifolds the Turbo was customized with special 50 trim inlet and T3 backside for the bigger Borgwarner wheel, Custom V band outlet.... turbo inlet is t2 based...Turbo supports 450+
Paid $1400 asking $1000...
Greddy 720cc injectors $300
ISIS polished intake manifold $80.00
Top mount fuel rail ....$50.00
custom throttle cable included if you just by it all together for $350!
Built SR20det Auto with custom High stall Torque converter... trans is same as Z32 auto But with upgraded Solenoids , extra clutch paks, reaction plates.....Manual valve-body recalibration .....Shifts are very quick and consitent....asking $1100 obo
KA turbo manifold stainless $60.00
KA 5speed trans $100.00 needs clutchkit
E-Boost 2 electronic Boost controller-Guage style boost and boost readout controller...Has 7 stages of boost control,gear based boost , overtake, etc all in a gauge style nice! $300.00 obo
Greddy VSPL intercooler with side greddy up pipes $300
I will try and get pic's up ...Just need the stuff gone moving on so its your gain.
Fairfax Virginia
571-235-9681
All ARP hardware
ER sportsman Rods
clevite bearings
$2000 OBO
((sr)) kelly
Engine / Exhaust / Drivetrain
10-28-2009 09:10 PM
