built poor mans gsr block 81.5mm bore ported b16 head
SHAWN
WOODBRIDGE VA 22191
CALL OR TEXT FOR PICTURES 703 772 8790
ASKING PRICE IS $2500 OBO AND THE MOTOR IS A TURN KEY START...ITS STILL IN THE CAR AND YOU CAN COME SEE FOR YOURSELF AND DRIVE IT MOTOR RUNS VERY STRONG ON JUST MOTOR AS IT SITS...AS OF TODAY THERE IS ONLY 1208 MILES ON THIS SETUP SINCE ASSEMBLED...SERIOUS BUYERS ONLY
I HAVE A BUILT POOR MANS LOW COMPRESSION 9:1 SETUP IN A GSR BLOCK FRSHLY BORED ND HONED 20 OVER 81.5MM BORE...
THE BLOCK
9:1 SRP TURBO PISTONS 81.5MM
EAGLE RODS WITH UPGRADED ROD STUDS
LS MICROPOLISHED ND BALANCED CRANK
ARP MAIN STUDS
ACL RACE MAIN AND ROD BEARINGS
GOLDEN EAGLE OIL SQUIRTER DELETE
HAS NEW OEM WATER ND OIL PUMP AND OEM HEADGASKET
THE HEAD
B16 PORT AND POLISHED HEAD
SUPERTECH FLAT BOTTUM VALVES, SPRINGS AND RETAINERS FOR TURBO
OEM VALVE GUIDES AND SEALS
INLINE PRO LS VTEC KIT...HEAD WAS FILLED AND TAPPED PREVIOUSLY BEFOR I HAD IT
ITR CAMS WITH BUDDY CLUB GEARS
INTAKE MANIFOLD IS A B16 SKUNK 2 PRO SERIES WITH RPM SERVICE 70MM THROTTLE BODY
AEM AFTERMARKET FUEL RAIL WITH B&M FUEL PRESSURE REGULATOR AND GAUGE
THE TRANS
STOCK GSR TRANSMISSION WITH FRESH SYNCROS
WOODBRIDGE VA 22191
THE BLOCK
ARP MAIN STUDS
THE HEAD
THE TRANS
Slo_jspec
Part Outs
06-13-2011 10:36 AM
Slo_jspec
Engine / Exhaust / Drivetrain
15
05-16-2011 09:31 AM
Duende
10-15-2010 12:38 PM
Gold Eg
08-26-2010 09:42 AM
Slo_jspec
Honda
08-21-2010 07:27 AM
