B20/vtec, Fresh OEM rebuild
mike
chester, va 23836
pm or text 804-712-1060
$1100 ..
will also give a start up warranty if need be.. the motor runs great
B20b bottom (99-00 spec)
Ctr head cast
3 angle valve job
new valve seals and valves lapped in
Gsr springs/retainers
2000 GSR cams
Arp headstud
Arp rod bolts
2000 b16 intak match ported to the head
all new gaskets and seals
p73 oil pump
b16 timing belt
6an oil feed
Catch can bung fittings in back of the block
has tapped oil pan on the motor cuz i was planning to go turbo but decided not to.. (tack welded the hole so no oil leaks)
The motor runs very well and I have no issue keeping it unless asking price is met.. The motor has around 2000 miles on it and runs flawless !!! The LMA did start to tap a little so im putting H22 LMA's in it this weekend (my stupid mistake to not replace them when everything else was replaced)... I'm going a different route so contemplating on selling my longblock... LMK if you have any interest or questions ill gladly answer any of them.. Thanks
chester, va 23836
$1100 ..
Ctr head cast
3 angle valve job
2000 GSR cams
Arp headstud
Arp rod bolts
p73 oil pump
b16 timing belt
6an oil feed
Re: B20/vtec, Fresh OEM rebuild
Well the car will be driven to World Cup finals this coming weekend .. I'll gladly meet otw or if you will attend the event you can see it there ..
Motor now has h22 spring style lma's and has itr cams now .. So pretty much a complete Ctr head now with 3 angle valve job and new valve seals .. I do want an extra 125 now though since it has itr cams ..
DORKO
Honda
49
06-09-2010 03:52 PM
