b16a short block/Built GSR head and random b series parts
Means of contact: text (434)426-6846
Price: $1500 takes it all or text for individual prices
Description:
Block: stock jdm b16a bottom end with approx. 40-50,000 miles.
Head: has about 100 miles on it since it was put together. it's a p72 with oversized crower valves, crower springs & retainers, itr cams, type r intake manifold, OEM head gasket, ARP head studs.
b16 cams
ls cams
DC header 4-2-1
AEM fuel rail
oem obd1 injectors
Hasport DA Integra motor mounts
uncut DA engine wire harness
stock resurfaced flywheel
stage 3 xtd clutch
half shaft and axles
obd2 alternator
b16 intake manifold and throttle body
ls intake manifold and throttle body
ls pistons and rods
Pictures: text for pics of whatever you need
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Description:
b16 cams
ls cams
DC header 4-2-1
AEM fuel rail
oem obd1 injectors
stage 3 xtd clutch
obd2 alternator
ls pistons and rods
live_civic7
Engine / Exhaust / Drivetrain
06-14-2011 08:18 AM
ant*
20
09-27-2010 08:06 AM
therealone
03-24-2009 06:34 AM
it2qwk4u
02-28-2009 10:01 PM
