b16 parts
$700obo for complete short block combo wit out water pump and got use oil pump if needed( not assembled Srp pistton,eagle h rod,block,crank may need to polish,pan,oil pick,cooling box,water neck
ok i found the shell i want and everything is for quick sale, if i buy the shell or the shell get sold am keeping everything.Also make offer b16/b17 eagle H-beam rods wit arp rod bolts $350 81.5mm forge srp pistons wit rings b16a-9.1 b18-10.1comp $250 H-beam attach to srp piston combo $500 b16a/17a,ls-vtec Arp head bolts New$100 Used $70 bare 81mm b16a2 block wit main caps $45 bare 81.5mm b16a2 block wit AC block gaurd,main caps $80 b16a oil pan,cover, and pick up $70 used oil pump jdm,usdm $35 b16 valve cover $25 Jdm LS hydro tranny need to put casing on which i have $200 Hydro B series Act stg4 6 pluck clutch and plate unsprung $150 Hydro B series lightweight flywheel $120 stock b16a cam gears $25 skunk2 pro tit cam gears $230 B16 toda timing belt $110 b16 buddyclub racing 2 layer 81mm HG $110 obd1 p28 chipped and mugen programed b20vtec $120 spy security alarm wit remote start $60 b16a stock pr3 rods $10 a rod b16 crank $40 :D:D:D |
Re: b16 parts
PENDING...piston,rod,block,crank,oil pick,tray,oil pan,water neck, coolant box,oil pump... PENDING
Re: b16 parts
guy never came through back ttt
Re: b16 parts
ttt combo price
Re: b16 parts
