b16 parts
b16 parts
$700obo for complete short block combo wit out water pump and got use oil pump if needed( not assembled Srp pistton,eagle h rod,block,crank may need to polish,pan,oil pick,cooling box,water neck
ok i found the shell i want and everything is for quick sale, if i buy the shell or the shell get sold am keeping everything.Also make offer
b16/b17 eagle H-beam rods wit arp rod bolts $350
81.5mm forge srp pistons wit rings b16a-9.1 b18-10.1comp $250
H-beam attach to srp piston combo $500
b16a/17a,ls-vtec Arp head bolts New$100 Used $70
bare 81mm b16a2 block wit main caps $45
bare 81.5mm b16a2 block wit AC block gaurd,main caps $80
b16a oil pan,cover, and pick up $70
used oil pump jdm,usdm $35
b16 valve cover $25
Jdm LS hydro tranny need to put casing on which i have $200
Hydro B series Act stg4 6 pluck clutch and plate unsprung $150
Hydro B series lightweight flywheel $120
stock b16a cam gears $25
skunk2 pro tit cam gears $230
B16 toda timing belt $110
b16 buddyclub racing 2 layer 81mm HG $110
obd1 p28 chipped and mugen programed b20vtec $120
spy security alarm wit remote start $60
b16a stock pr3 rods $10 a rod
b16 crank $40
b16 valve cover $25
b16 crank $40
b16crx000
Want to Buy / Trade ARCHIVE
10-20-2007 08:53 PM
