B series Parts + Integra Stuff
Means of contact: 703-785-8895
Trades: Skunk2 Pro2 Cams and cam gears, New Spring style LMAs, ARP studs -GSR head -mains -intake -exhaust, B Series Vtec Valve cover, 68mm B Series Throttle Body, PWJDM/Yowai SS Whale PP intake, RDX injectors, lmk what you have
Description:
P75 head - As is, has one obvious bent valve. COMES w/CAMS AND VALVE COVER!. - was $80 - Asking $75
[ATTACH=CONFIG]119679[/ATTACH]
B16 head - As is, no cams, no vc, no im, no dizzy. Includes full valvetrain, all cam caps, oil rails, lifters, LMAs, etc.. and coolant neck. Needs to be resurfaced and cleaned up -new price $250
[ATTACH=CONFIG]124181[/ATTACH][ATTACH=CONFIG]124182[/ATTACH]
SLP 2.5" stainless shotgun/loudmouth resonator - came off GTO - $50
APC Air filter, great shape, with filter oil & reducers - $20
[ATTACH=CONFIG]119686[/ATTACH]
Billet aluminum oil cap, machined aluminum finish, no brand, fits Honda valve covers - $25
One set of GSR cams one of the "bearing" surfaces on one cam (only one) has a nick in it, got them that way. Can be fixed by someone with a lathe, or you can throw the good one in a motor to replace a B16 cam - $15
Two (2) Drag DR-29 wheels, 15x7, 40 offset , 4x100, one is gold and is pretty much perfect, the other is flat green and will need to be painted to match, neither are bent, no curbage. I bent some wheels last winter These two good ones have been sitting since. The gold one has a tire that's bald and the green one has no tire.
I paid $90 shipped for the gold wheel and used it for 3 months. - $100 for the pair.
[ATTACH=CONFIG]119682[/ATTACH]
TSX 6 speed shift knob with red lettering (part number: 54102-SEC-A01) - $40 - make an offer
(picture not actual, mine is a little more worn)
[ATTACH=CONFIG]124185[/ATTACH]
OEM driver's side and transmission side mounts good shape (rear mount was broken) - $30
94-97 LS OEM header (both pcs) and heat shields - make offer
Lower half of front bumper for 94-97 Integra - $35
94-97 LS OEM airbox assembly - $35
94-97 turn signals, great shape - $25
94-01 Driver's side side skirt, black plastic unpainted - $20
94-97 Integra power mirrors (one is missing glass) $25
94-01 Integra hatchback 3rd brake light $20
94-01 Integra rear wiper motor and arm $20
94-01 Grey "Oh $hit!" handle - $5
94-01 Black passenger side power door lock plate with switch - $5
Everything has been kept inside, out of the weather.
Description:
