B D & H SERIES PARTS!! Water Pumps, Covers, Cams, Oil Pan, Mounts, ETC!!!!!!!!!!
hey guys , I have some D, B & H Series parts for sale. let me know if your interested.
Pm me an offer if your interested. Need a part you dont see, Ask me and Ill see if I got it.
Text me for fastest response 814-505-8989
located in central PA
Im also Paypal Verified
PARTS:
B Series Flywheel
(3 Sets) LS B18 Non-Vtec Cams with Cam Gears
Manual Pedal Assembly from 97 Civic
EG/DC B Series Rear T/L Tranny Bracket
(2) D Series Rear T/L Tranny Brackets
LS B18 Non-Vtec Valve Cover
B18C1 GSR Bottom End Girdle
D Series Engine Block 2 Post Mount
(3) D Series Lower Timing Belt Covers
(2 Sets) H Series Shifter Linkages
(2) D Series Fuel Rails
(3) B Series Upper Inside Timing Belt Covers
B Series Outer Upper Timing Belt Cover
LS B18 Windage Tray
Tapped LS Oil Pan B18
(4) LS B18 Water Pumps
D Series Z6 or Y8 Vtec Cam
Set of LS B18 Rods & Pistons
(4) B Series Rear Main Seal Covers
(2) H/F Series H22/H23 Starters
(4) B/D Series Throttle Bodies
Civic Firewall Mounted Map Sensor
(4) B16 Rods
(4) LS B18 Pistons
LS B18 Non-Vtec Head
Miscellanous D & B Series Parts-
Clutch Fork, Coolant Pipes, Thermostat Housings, Timing Belt Tensioners, Crank Gears, Fuel Presure Regulators, Vtec Solenoid, Sensors, Oil Pick ups, Rear Block Breather Boxes, Charcoal Canisters
Miscellanous OBD1 & OBD2 Sensors/Plugs from wiring harnesses. Pm/ Text me what your looking for and I'll See if I have it
PARTS:
B Series Flywheel
LS B18 Windage Tray
(4) B16 Rods
(4) LS B18 Pistons
