aftrmrkt bseries fuel rail, 81.5mm CP/SRP/JE rings, and headgasket, Type R oil pump
Old 06-27-2013, 09:39 PM
96sirhatch's Avatar
96sirhatch has disabled reputation
Default aftrmrkt bseries fuel rail, 81.5mm CP/SRP/JE rings, and headgasket, Type R oil pump
CLOSEEEE
96sirhatch is offline
Old 06-28-2013, 12:45 AM
II Always
mgs1098's Avatar
mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098
Default Re: aftrmrkt bseries fuel rail, 81.5mm CP/SRP/JE rings, and headgasket, Type R oil pu
I have a Benen rail. Text if interested.
Alan
mgs1098 is offline
Old 06-28-2013, 04:11 AM
96sirhatch's Avatar
Texted you
Alan
Old 06-28-2013, 08:03 PM
cf191107's Avatar
cf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these partscf191107 is infamous around these parts
I got buddy club hi comp head gasket if ur intuerested
cf191107 is offline
Old 06-28-2013, 08:09 PM
cf191107's Avatar
Its never been torqued down its still in great condition, but it was test fitted on the block with head studs and then put the head on to test fit but never torqued it down, but there is minor scratches from when test fitting it but its still never been ran or torques down and I belive the material the scratches are thru are ment to form to the head and block as u torque it down I could show u better in person but just being strait up with u if u are interested let me know and I can show u what I'm talking bout but its def still in optimal condition I was ganna save it for a build later on down the road but I'm broke with my first build so hell no to a second lol lmk man I'll check back
cf191107 is offline
Old 06-28-2013, 09:53 PM
96sirhatch's Avatar
No thanks buddy, I am going low comp, I REALLY appreciate the offer though!
Old 06-29-2013, 11:18 AM
cf191107's Avatar
no prob good luck with the build
cf191107 is offline
Old 06-29-2013, 08:18 PM
96sirhatch's Avatar
Thanks!
Old 07-06-2013, 03:22 PM
96sirhatch's Avatar
Old 07-07-2013, 07:25 AM
EF9SIR's Avatar
EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR EF9SIR
crower springs and retainers exedy twin disc for b-series
EF9SIR is offline
Quick Reply: aftrmrkt bseries fuel rail, 81.5mm CP/SRP/JE rings, and headgasket, Type R oil pump
