60-1 Neon Turbo Kit, Big Godspeed FMIC, Box Intake Mani
Name- Lucas Harman
Location- Waynesboro VA 22980 Means of Contact- PM or email laharman707@gmail.com Godspeed Spec V Front Mount Intercooler, core size is 12”tall x 24”wide x 3”thick. 3” inlet and outlet, bar and plate design, rated to 600 horsepower. Polished aluminum, small dent in upper portion, see pics. The dent shouldn’t hinder flow at all. 31.5” overall length from inlet to outlet. $150 + shipping https://i129.photobucket.com/albums/...70550Small.jpg https://i129.photobucket.com/albums/...70551Small.jpg https://i129.photobucket.com/albums/...70552Small.jpg https://i129.photobucket.com/albums/...70553Small.jpg I’ve decided to go bigger so up for sale is my turbo kit off of my racecar. I made 403whp on 16lbs of boost with this setup on my srt bottom end 2.4. The turbo kit I would like to sell as a whole as it is all made to work together, if after a few weeks no one bites then I’ll part it out. Turbo “kit” - $1300 The “kit” consists of the following 60-1 Turbonetics turbo, t3, T04S cover, 360 degree thrust bearing, stage V turbine in .82ar housing Rare Mexican Stratus log manifold modified to accept TiAl 38mm wastegate TiAl 38mm wastegate with 13lb spring Wastegate dump tube Porsche Intercooler (front bumper cutting required) Porsche Radiator Turbonetics Godzilla BOV (the biggest BOV out there I think) 2.5” and 3” piping, couplers clamps etc. HKS Filter Turbonetics Manual Boost Controller https://i129.photobucket.com/albums/...1-27140843.jpg https://i129.photobucket.com/albums/...1-27140859.jpg https://i129.photobucket.com/albums/...1-27140935.jpg Heres a vid of my car with this kit on the dyno Box Intake Manifold for 2.0/2.4 Neon – totally custom flange, runners etc. The runners are kinda small I.D. but it worked for me at 400hp! 65mm mustang throttle body flange (TB not included) Prof. painted gloss black – $275 https://i129.photobucket.com/albums/...1-27141001.jpg All prices do not include shipping. |
Re: AEM Tru Boost, 60-1 Neon Turbo Kit, SRT tubular manifold + more
will the box intake mani accept a stock tb??
And u got any pics of the hp racing turbofold? |
bump for a good dude, and quality stuff. cant wait to see what you got planned this time.
The intake will not accept a stock TB without either an adapter plate or welding a new end cap on that is drilled for the stock TB pattern.
I'll inlcude the TB for 30 bucks extra but you will losed your stock IAC. I ran megasquirt and it didn't require an IAC so the mustang TB worked well.
Originally Posted by mxryan
(Post 6802969)
Thanks Mike!!
this years setup should be....interesting :-)
Originally Posted by Jdmhore
(Post 6803062)
Can't wait, hopefully I will get to come out and play a lil this year!
Originally Posted by Lucas_Harman
(Post 6803343)
Thanks Mike!!
this years setup should be....interesting :-) |
you made over 400 whp @16psi on a 60-1, cant be done.
Originally Posted by escortL7
(Post 6813284)
Give ole Jim Riddle of Valley Dyno a call if you don't believe me. My setup setup made low 300's on 9psi with very conservative timing and it was pig rich....do me a favor and stay out of this thread unless you wanna buy something. |
Edited to remove items sold. Make offers!
PM me about the godspeed fmic
