96 Ka24de Motor/Trans/Ecu plus goodies
True Customs
NOT FOR SALE ANYMORE I NEED IT
I pulled the motor to swap in a sr20. I drove it daily until it got pulled. No problems at all. I almost felt bad for taking it out but boost is good.
All you will need from your car is the ac pump, water temp sensor, transmission sensors, and lower harness. Everything else is still there from spark plug wires to the oil pan. Sorry no nismo cap just stock one. Has low mileage clutch/flywheel/alternator.
Comes with
-Complete 96 motor 149,335 miles ( $500 complete all u need is your harness , a/c pump and water temp sensor) oh and your own transmission flywheel clutch
-5 speed transmission attached /smooth shifts no grinds/ had redline fluid in it ($200 needs sensors from your old trans)
-Complete 96 upper harness uncut ($100)
-96 manual ecu ($80)
-F1 lightweight chromoly flywheel /low miles ($100)
-Exedy stage 2 puck clutch/ low miles/no slips ($200)
-like new aem intake with s14 maf attached ($125 w/o maf) ($50 for maf)
-stock fan with clutch with shroud ($50)
-a/c electric fan ($30)
-exhaust from header to test pipe ($30)
Other Ka24de parts i have
-95 a/c Compressor $30
-95 power steering pump $30
-Motor mount brackets $20
-I have like a whole s14 front body harness let me know if you need anything from it
Comes with
