1994 RX7 Efini R2 Engine/Transmission partout! 50k miles on everything.
Means of Contact: PM
Description:
Ok, I have a complete engine and transmission from a 1994 Efini R2 that I am parting out. All parts have 50k original miles on them! If you need something off of the motor or transmission that you do not see listed, PM me and I will let you know if I have it and how much I want for it. I have attached pictures of everything that I have pictures for currently. I can get pictures of other parts if you want also, just let me know.
Bare Shortblock: 50k miles, blown coolant seal but ran fine before that. I may pull it apart and sell it in pieces if no one wants a complete shortblock for a rebuild
$400 + shipping
5-speed Transmission: This J-spec transmission has the .806 5th gear. If you have a bad syncro or grinding trans in your FD, here is a cheap fix.
$450.00 plus shipping
Starter
$50 Shipped
Radiator + Fans
$200 shipped
Alternator
$50 shipped
A/C compressor
$100 shipped
UIM
$75 shipped
LIM
$65 shipped
Power steering pump/pulley
$85 shipped
Air pump
$50 shipped
Exhaust manifold: No cracks at all.
$100 shipped
OMP
$100 shipped
Factory air box
$40 shipped
Rats Nest Solenoids: all worked great when removed, perfect boost response/pattern
$20 shipped each (I have 7 available)
Duty Solenoid
$30 shipped
Throttle body
$100 shipped
Y-pipe
$50 shipped
Primary Fuel rail/injectors
$75 shipped
Secondary Fuel Rail/ Injectors
$75 shipped
Stock Intercooler: I have 2 available
$ 40 shipped each
ECU: I have one 1993 USDM ECU and one 1994 JDM ECU
$40 shipped each
Motor Mounts:
$50 shipped for both
Pressure Chamber #1
$30 shipped
Pressure chamber #2
$30 shipped
[/QUOTE]
Ignition Coils
$175 shipped for all
Thermostat housing:
$50 shipped
Karbonlite CF Vented hood: Some small cracks and hoodpins could be replaced
$100 + shipping
Air Control Valve
$40 shipped
Plastic Oil Fill Tube
$50 shipped
AC Condenser
$75 shipped
New NGK leading/trailing plugs with 200 miles on them, set of 4
$10 shipped
JDM downpipe with no pre-cat!
$60 shipped
a set of twin turbos with no cracks in the housings:
$200 + shipping
dual oil coolers
$400 + shipping with all oil lines
driveshaft
$50 + shipping
Stock PPF
$50 + shipping
Feel free to make me an offer, or ask if you need a part that you don't see.
Description:
$400 + shipping
Starter
$50 Shipped
Radiator + Fans
$200 shipped
Alternator
$50 shipped
A/C compressor
$100 shipped
UIM
$75 shipped
LIM
$65 shipped
$85 shipped
Air pump
$50 shipped
$100 shipped
OMP
$100 shipped
Factory air box
$40 shipped
Duty Solenoid
$30 shipped
Throttle body
$100 shipped
Y-pipe
$50 shipped
$75 shipped
$75 shipped
$ 40 shipped each
$40 shipped each
Motor Mounts:
Pressure Chamber #1
$30 shipped
Pressure chamber #2
$30 shipped
[/QUOTE]Ignition Coils
Thermostat housing:
$50 shipped
$100 + shipping
Air Control Valve
$40 shipped
$50 shipped
AC Condenser
$75 shipped
$10 shipped
$60 shipped
$200 + shipping
dual oil coolers
driveshaft
$50 + shipping
Stock PPF
$50 + shipping
