1994 caprice with 357 lt1 and boltons
Old Nov 1, 2009 | 01:54 PM
804GSX91's Avatar
804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold804GSX91 is a splendid one to behold
Default 1994 caprice with 357 lt1 and boltons
* Name: Jamie
* Means on contact: PM this thread or email Lewisjo08@hotmail.com
* Trades: No trades found my next project already selling this to purchase it lol
* Price: $2,500 obo
* Description:
Hey Everybody,
Think it’s about that time for me to move on from my 94 caprice. I am wanting a new project and have no room for this,my astro and another project. I will list below what the car has and what the car needs
Engine - Jasper 357cid LT1, and includes the following:
* Accel 30 lb./hr. injectors
* Hooker Super Comp equal-length headers (1.75" primaries)
* F-body EGR valve
* De-screened MAF
* Hypertech 160 thermostat
* MSD GM Blaster coil
* Taylor 8 mm Spiro-Pro wires
* Custom intake pipe with K&N filter
* Custom cold-air box
*Corvette Mini Starter
Dynomax Catback with polished ss mufflers and custom ota pipes exiting right after the rear wheels
PCM (Powertrain Control Module), OBD-I, custom programmed by Bryan Herter, which includes the following: (also have a pcmperfromance tune,tuned for the edge converter and 2.93 gears)
* Power Programming
* Speed limiter eliminated
* Speedometer calibrated for exact tire height and rear end gear ratio
* Calibrated for 30# injectors
* Fans on/off temperatures reprogrammed to work with the 160 thermostat
* LT4 knock module
Drivetrain Team Tripp Lvl 2(3/4 burnt up):
* Stage 3+ shift kit
* Billet servo
* Raptor sunshell
* Tru-cool crossflow transmission cooler
* 2.93 rear end gears
* Inland Empire aluminum driveshaft
500 mile Street Edge 9.5 inch 3200 rpm stall
Brakes
* KVR Cross-drilled rotors in front
* EBC GreenStuff Kevlar brake pads
Suspension
* Eibach progressive-rate lowering springs (smooth ride but really tightens up in the curves when you need it)
* Front & rear sway bars (rear bar is Impala SS unit)
* Koni "Red" shocks up front, KYB "Gas-A-Just" in rear
* Prime 200 16x8 wheels
* Falkin Ziex 712 tires (255/50 rear, 225/55 front)
Gauges
* Gaugeworks interior dual gauge pod
* Auto Meter "Z-Series" Cylinder Head Temperature gauge, mounted in the pod
* Auto Meter "Z-Series" Transmission Temperature gauge, mounted in the pod
* Auto Meter "Sport Comp" Boost/Vacuum gauge, mounted on the hood
* Auto Meter "Sport Comp" Fuel Pressure gauge, mounted on the hood
* (2)Auto Meter "Sport Comp" Air/Fuel Ratio gauges, one for each bank, mounted in the dash bezel
* Autogauge 8,000 RPM Tachometer with shift light, mounted under the dash
Appearance(paint on this car is amazing for a 15 year old car)
* Caprice SS rear quarter-panel scripts
* White reflective "bow tie" on the trunk
* LTZ hood emblem
* Modified front corner lamps (added extra bulbs, also a safety feature)
* Pinstriped and color-matched tail light lenses
* Caprice SS dash plate
Car does have some issues,
-Trans needs to be rebuilt. Does not have ¾ at all still has ½
-Rear Sway bar is loose,I would suggest upgrading to 96 arms because they have a better mounting points
-Bumpers could use a repaint.
-Front door panels are cut where the speakers are,I was going to go with the Will B Speaker Pods
-Drivers Side door has a minor dent,(you honestly can't see it unless you are about 5 ft from car)
-passenger side cat should be replace,passed inspection fine,but has a hairline crack in it
-no radio
-air needs to be recharged
I probably am forgetting some stuff but if you have any questions at all you can send me a pm. Thanks
Asking 2300 obo, will consider trades, let me know what you have.
Please contact me if you're interested.
* Details:
o Mileage: 204k on body 65k on engine
o Exterior Condition: Pretty nice except bumper could stand a repaint and dent on drivers door.
o Interior Condition: ok all their
o Modifications: Listed above
Old Nov 2, 2009 | 09:37 AM
fullsize fun's Avatar
World Famous VF-14
fullsize fun is a splendid one to beholdfullsize fun is a splendid one to beholdfullsize fun is a splendid one to beholdfullsize fun is a splendid one to beholdfullsize fun is a splendid one to beholdfullsize fun is a splendid one to beholdfullsize fun is a splendid one to behold
Default Re: 1994 caprice with 357 lt1 and boltons
Man I KNOW you are not getting rid of Casper......
Old Nov 2, 2009 | 10:33 AM
804GSX91's Avatar
Doubt man just seeing if there is any intrest
Old Nov 4, 2009 | 09:44 PM
C16EFSedan's Avatar
SG
C16EFSedan has disabled reputation
Hoping your listed price is wrong? If not... trade for a mintttttttttttt durango?
Old Aug 27, 2010 | 12:44 PM
egcivic93's Avatar
egcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these partsegcivic93 is infamous around these parts
hey man do you still have this car?
Sandfrog
Feb 18, 2008 10:29 PM
