Quick technical question
Chillaxin
Im not buff when it comes to cars or bikes, so please explain to me. I know the difference (sorta) in the actions of both, but im not sure why one is better. Carborated or fuel injected. I remember Del Sol mentioning the '03 R6 was fuel injected, so im assuming that made it better than the older ones because they are carborated, can someone explain why this makes a huge difference?
Carburettors = hesitation or "flat spots" when trying to accelerate rapidly. Unless an accelerator pump is used.
Fuel Injection = no hesitation, doens't need tune-ups (unlike carburettors.)
I personally own a 03 cbr 600rr which is fuel injected, and my friend owns a carburetted bike. I have rode both, and for instant throttle response, fuel injection is the way to go. Plus a fuel injected bike will fire up with out any hesitation unlike a carburetted bike.
Chillaxin
Originally Posted by freq
The difference between carburettors and fuel injection systems is minuscule. The carburettor mixes fuel with air to form a combustible mixture. So does a fuel injection system. The difference, however, is that with carburettors, fuel is sucked into the air, while with fuel injection systems, fuel is squirted into the air.
The difference between the two is not so miniscule....................here's why:
Say I buy a carb'd bike. I then buy a jet kit for the carbs so I can have it dyno tuned at a shop, say D&D for instance. So I do it. Then I throw a slip on on it. Then I have to have the jets re-tuned on the dyno. Then I put a cam in it. Then I have to have the jets re-tuned..............again.........lots of mula involved everytime.
Say I buy a fuel injected bike. First purchase I make is a Power Commander. Then I buy a slip on. I go online, find my make and model bike with the exact slip on that I just installed and download the map. I then reflash the PC. And again and again with whatever mods I decide on. Much cheaper. I can also have a different flash for street and track riding. All on the fly without moving the bike!
So if you're going to do allot of modding I would opt for an FI bike. If you're going to keep it relatively stock you can go with either or.
Hope this helped!!!!!!!
