power commander
Old Nov 15, 2004 | 05:44 AM
seanazzy's Avatar
seanazzy is an unknown quantity at this point
Default power commander
think i need to get it. 99 gsxr750 with d&d slipon and k&n airfilter. running lean and tired of it. anybody know my options? isn't there one that you can adjust from the device itself instead of hooking up to a laptop? any info would be much appreciated...thanks
Old Nov 15, 2004 | 08:01 AM
Del La Sol 1320's Avatar
Del La Sol 1320 has disabled reputation
Default Re: power commander
they are all adjustable from the unit, but to really get it dialed in correctly you need to have it dyno tuned with an a/f meter... i believe your year gsxr takes the PCII... but i would try putting in a stock air filter and see if that helps, there aren't many suzukis that respond well to K&N's, even with mapping we've had problems getting them to run right because you just can't add enough fuel to compensate for the extreme lean mixture
Old Nov 15, 2004 | 08:41 AM
seanazzy's Avatar
i just dropped the k&n in because it started with the stock filter. i even tried putting the stock exhaust back on and resetting the computer, but no go. so, i think i need the power commander if i really want to fix this problem. been looking on the website and i'm a little confused...it shows maps for certain exhausts and certain riding, but none really match my needs. is there a way to set it regardless and are the maps free downloads? thanks for any info
Old Nov 15, 2004 | 08:43 AM
if they dont' have one for you you'd just have to get one custom made, ie dynotuning
Old Nov 15, 2004 | 10:22 AM
sprayedcivic's Avatar
On One Wheel
sprayedcivic has disabled reputation
redline in yorktown builds custom maps for pc's he has a dyno
Old Nov 16, 2004 | 07:17 PM
ron2k1's Avatar
ron2k1 has disabled reputation
i highly recommened redline they did i great job on my custom maps for my gsxxr1000
dude man
Jan 21, 2008 01:40 PM
Ej8D16y8-T
Feb 11, 2006 06:26 AM
stang4ever
Nov 10, 2005 10:36 AM
mnchvgs79
Apr 20, 2005 04:09 PM
