Need help pls.
Old Apr 20, 2008 | 07:30 PM
KiLLa BeE's Avatar
KiLLa BeE is an unknown quantity at this point
Default Need help pls.
I bought an 01 600F4i earlier this year and the guy that had it before put a fender eliminator kit. It still uses the stock turn signals though. The problem is, the turn signal stays on all the time. It still works as a turn signal though, but when it's not in use, it's just on and bright as hell! Is it rigged somehow? I checked the connectors, and it seems to me that it wasn't messed with(cut wires etc.) Anyone know how I can fix this? Turn the signal lights off when not in use?
Old Apr 21, 2008 | 03:31 PM
KiLLa BeE's Avatar
Default Re: Need help pls.
lol, ok nevermind... the flush mount LED's that the former owner installed were wired wrong or something. I disconected the flush mounts to test them and BAM! Now I gotta figure out how to wire them right O_o so it'll all work together right.
Old Apr 21, 2008 | 03:58 PM
Real Random's Avatar
they should be on until the turn signal is activated to cause it to flash
i would not disconnect anything
it is better to be seen than not
Old Apr 21, 2008 | 07:17 PM
KiLLa BeE's Avatar
Well I was trying to install an integrated led tail light and that running light was causing it to not work properly. It would cause the turn signal part on the integrated tail light to stay on and the brake light part to not work at all. So, I just disconnected the running light wire and it fixed the problem. Now, I have a much cleaner look on the tail part. It used to have those huge turn signals on the back attached to my fender eliminator. I took those off and replaced the brake light with the integrated LED ones. Everything works fine now. The only thing is, the flush mounts doesn't stay on like it used to. But, it works fine when flashing. Now I should put some neons on the side to be seen better
Old Apr 21, 2008 | 08:13 PM
neons no
LEDs yes
post pics
Old Apr 22, 2008 | 08:46 AM
KiLLa BeE's Avatar
lol, i was jk bout the neons... I'll post some before and after pics later... my gf has my camera so I have to borrow someone else's
Old Apr 22, 2008 | 10:17 AM
chappe's Avatar
SV haver
chappe chappe chappe chappe chappe chappe chappe chappe chappe chappe chappe
make sure to post them pics of your bike in the proper thread too..... please....
Old Apr 22, 2008 | 05:47 PM
KiLLa BeE's Avatar
hmm, which thread? the "Post Pic(s) of a sick bike!!" thread?
ok, will do
Old Apr 24, 2008 | 05:32 AM
KiLLa BeE's Avatar
before
after
sorry for the bad pics...took some quick ones at night just for show purposes
Old Apr 24, 2008 | 06:05 AM
chappe's Avatar
SV haver
looks good
