motorcycle techs?
Old Oct 2, 2008 | 02:09 PM
mikethomas's Avatar
Virginia Beach
mikethomas can only hope to improve
Default motorcycle techs?
Is it a big job to replace the shift shaft assembly on a 99 YZF600. Is there anybody on here that would be intreasted in doing the job? How much do you think it would cost. Thanks for all the help.
Old Oct 2, 2008 | 02:18 PM
EMCracing's Avatar
EMCracing will become famous soon enough
Default Re: motorcycle techs?
PMed
Old Oct 2, 2008 | 02:21 PM
skr00zloose's Avatar
hatrs make me famous
i'm not 100% sure on that particular bike, but most shift shafts don't require much work to get them out. there's usually a clip that has to be removed from the shifter end of the shaft, then the clutch cover, clutch, and some misc things (depends on the bike) have to be removed, then you can get the shaft out. it's not too much work, but if you're not comfortable doing it, give me a shout, we can work something out, i'm sure.
how'd the shaft get damaged anyway?
Old Oct 2, 2008 | 02:22 PM
mikethomas's Avatar
Virginia Beach
Broken chain
Old Oct 2, 2008 | 02:24 PM
EMCracing's Avatar
they are not that big of a job
Old Oct 2, 2008 | 02:26 PM
Originally Posted by mikethomas
Broken chain
you talking about the shift shaft or the clutch pushrod? i've never actually seen anyone break a shift shaft from a broken chain, but it's possible.
Old Oct 2, 2008 | 02:27 PM
EMCracing's Avatar
may have bent it that is posible
nftuatn
May 26, 2008 08:02 AM
BSeriesTurbo
Mar 14, 2007 06:17 PM
EgSick
Mar 3, 2006 10:33 PM
Stea1thy
Feb 22, 2006 10:54 AM
battlebart
Apr 5, 2005 07:08 AM
