Help: Reset FI light
I have a 2006 GSXR 600, FI light is on. I shorted the wires and retrieved C00 code which I researched online means "no fault". I tried resetting it by disconnecting batter, pressing trip and mode button and no work at all. Does any one know how to reset them? Thank you...
Re: Help: Reset FI light
i have noticed alot of the newer gixxers have had the problem of the fi light coming on for no reson andstaying on ... not exactly sure why but or how to correct but if you check out www.gixxer.com im sure you could get some help with that
sounds like mi honda
do you have the service manual?? If not I have a digital copy of the 06-07 600 and 750 manuals and can burn it to cd for you if you need it!!
Originally Posted by Robs750
(Post 4144432)
Originally Posted by sprayedcivic
(Post 4143637)
pull the battery cables off the battery and hold them together for a few seconds. there's capacitors in the ecu that hold a charge, and shorting the battery cables together (while not hooked to the battery, obviously) discharges the capacitors and resets the ecu.
that trick works on just about any car/truck/bike/boat/whatever that has a computer running anything on it. |
Yeah its not a problem I can definitely make a copy for you. Where are you located at I can meet you somewhere sometime or just mail it to you whichever you prefer!?!
Originally Posted by skr00zloose
(Post 4144446)
that trick works on just about any car/truck/bike/boat/whatever that has a computer running anything on it. Well I did that too, well shorted it for about a second or two, but nothing happen... |
(Post 4144450)
| All times are GMT -8. The time now is 04:06 AM. |
