Help: Reset FI light
Old May 25, 2008 | 06:08 AM
ScrewD03's Avatar
Slowest 240 EVER
ScrewD03 ScrewD03 ScrewD03 ScrewD03 ScrewD03 ScrewD03
Default Help: Reset FI light
I have a 2006 GSXR 600, FI light is on. I shorted the wires and retrieved C00 code which I researched online means "no fault". I tried resetting it by disconnecting batter, pressing trip and mode button and no work at all. Does any one know how to reset them? Thank you...
Old May 25, 2008 | 08:34 AM
sprayedcivic's Avatar
On One Wheel
sprayedcivic has disabled reputation
Default Re: Help: Reset FI light
i have noticed alot of the newer gixxers have had the problem of the fi light coming on for no reson andstaying on ... not exactly sure why but or how to correct but if you check out www.gixxer.com im sure you could get some help with that
Old May 25, 2008 | 03:01 PM
Real Random's Avatar
sounds like mi honda
Old May 25, 2008 | 04:25 PM
Robs750's Avatar
Robs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these partsRobs750 is infamous around these parts
do you have the service manual?? If not I have a digital copy of the 06-07 600 and 750 manuals and can burn it to cd for you if you need it!!
Old May 25, 2008 | 04:32 PM
ScrewD03's Avatar
Slowest 240 EVER
I don't have a service manual, if you can make me a copy I would really appreciate it...
Old May 25, 2008 | 04:33 PM
ScrewD03's Avatar
Slowest 240 EVER
Yah, I searched gixxer.com but didn't really find anything... I'll make a post then to make it easier. Thanks
skr00zloose's Avatar
hatrs make me famous
pull the battery cables off the battery and hold them together for a few seconds. there's capacitors in the ecu that hold a charge, and shorting the battery cables together (while not hooked to the battery, obviously) discharges the capacitors and resets the ecu.
that trick works on just about any car/truck/bike/boat/whatever that has a computer running anything on it.
Old May 25, 2008 | 04:35 PM
Robs750's Avatar
Yeah its not a problem I can definitely make a copy for you. Where are you located at I can meet you somewhere sometime or just mail it to you whichever you prefer!?!
Old May 25, 2008 | 04:55 PM
ScrewD03's Avatar
Slowest 240 EVER
Well I did that too, well shorted it for about a second or two, but nothing happen...
ScrewD03's Avatar
Slowest 240 EVER
Since your from VA Beach, I could just meet you somewhere... I live in TCC area...
