02 Ninja headlight problems
Old Jul 28, 2010 | 09:27 PM
ahhwataday's Avatar
ahhwataday has disabled reputation
Lightbulb 02 Ninja headlight problems
Weeeeelllll, I sold my 2002 Kawasaki Ninja 250. On the way to meet the buyer I stopped by a friends. I come back outside and start the bike but no headlight, high or low beam.
Do these bikes have this issue or is it just my bike?
Is there one bulb or two? If two I doubt they would both go at the same time, unless thata how they are wired
Im guessing its not the bulb bc when I flip the switch to high beam, the indicator doesnt light.
Im wondering if there is a fuse, relay, wire problem, or the switch goes out?????
I sold the bike but I am going to get this problem straight. I cant look it all over right now and I may not have the correct tools when I go check it out. Please let me know where I should start.
Thanks, Roy
PLEASE HELP!!!!!!!!!
Old Jul 29, 2010 | 03:26 AM
Quentin's Avatar
beautiful struggle
Quentin has disabled reputation
Default Re: 02 Ninja headlight problems
You can probly find your answer here http://forums.ninja250.org/
I had a Ninja 500 and it only used one single buld for the high/low. And checking the fuses is pretty easy. On my 500, all you had to do is lift the seat up and it would be near the battery under a black rectnagle cap. Not sure how comparable the 2 bikes are, I figured at least a little. None-the-less check that 250 website.
Old Jul 29, 2010 | 04:19 PM
ahhwataday's Avatar
Cool thanks. Im guessin its the fuse.
Now I wont have to go over not knowing. I thought I would have to take it all apart and dig around for the fuse
Old Jul 29, 2010 | 05:18 PM
skr00zloose's Avatar
hatrs make me famous
alot of kawi's also have a relay that won't let the headlight turn on until the bike is running, or has at least turned over a lil bit, might want to check that relay also, if applicable.
Old Jul 30, 2010 | 07:08 AM
Halfrican's Avatar
I like grape drank
Plus one, I've got an 07 250, the relay for whatever reason took a crap on me. Let us know if you got it working. Tell the kid who bought it ninja250.org is a gift from God. It has everything imaginable on there...everything you need and then some.
Old Jul 31, 2010 | 09:39 PM
ahhwataday's Avatar
WEll I went into the yamaha shop on mechanicsville tpke, ended up runnin into the new owner, They told me they took it to velocity and got it takin care of. Ive texted to find out what it was but havent received a reply. Ill let you guys know as soon as I find out. Thanks for the help.
Really starting to get into bikes and the more I know the better
Looking at a cbr600 tomorrow
Old Aug 1, 2010 | 10:38 AM
TateEvan's Avatar
TateEvan has disabled reputation
Most of the time on the Kawis it's the relay.
Spindrift
Mar 17, 2009 02:48 PM
BatEclipse99
Jan 4, 2009 12:40 PM
jdm_ef
Sep 25, 2008 07:40 AM
In the Works
Nov 23, 2006 10:45 AM
