Your perfect engine..
Old May 9, 2008 | 04:37 AM
  #41
shawn22's Avatar
FUCKIN MAGNETS
Default Re: Your perfect engine..
Originally Posted by XCELR8
I always thought 400ci was the limit!
Only for Gen 2 smallblocks (LT1/LT4) because they didnt have enough material in the blocks.
Old May 9, 2008 | 04:52 AM
  #42
1998Silverbird's Avatar
Team Ultra Slow
1998Silverbird is an unknown quantity at this point
Originally Posted by UNCLEBENZ
Maybe this weekend - going in a '03 Cobra -
3.4 Liter Whipple on a well breathing 5.0Liter stroker.
SC capable of 30 psi - going to run anywhere from 15 to 20 psi -expecting 700/800 rwhp/tq. (at 93 octane and 20 psi)available at 2500 rpm to 7200rpm.
we'll see.....
Updated picture
Its going to be Slow!!
Old May 9, 2008 | 05:02 AM
  #43
Team Ultra Slow
My perfect engines would be...
For my Daytona The Iroc RT motor's of 92-93
http://www.moparautos.com/images/ebay%20002.jpg
For the T/A the LS9 of course
http://image.sportcompactcarweb.com/...ls9-engine.jpg
Old May 9, 2008 | 05:28 AM
  #44
Beachin_240's Avatar
Snoochie boochies
Beachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond repute
Rotary, you say?
http://www.youtube.com/watch?v=zt-sK4Fd94Q
Old May 9, 2008 | 05:39 AM
  #45
euro sport's Avatar
I wupped Batmans ass
euro sport is a name known to alleuro sport is a name known to alleuro sport is a name known to alleuro sport is a name known to alleuro sport is a name known to alleuro sport is a name known to alleuro sport is a name known to all
8.0L W16 w/ quad turbos from the Veyron is a pretty badass motor.
987 hp / 922 ftlb
7mpg city / 10mpg highway
3mpg @ top speed
Old May 9, 2008 | 07:57 AM
  #46
Will Sol's Avatar
My project done to the extreme
the E30 325es bottom end with the 325Is top end... built and then boosted to put down a reliable 350-400 rwhp.
Or for the SS - LS7 built then twin turbo\'d
Old May 9, 2008 | 08:12 AM
  #47
Lord Humongous's Avatar
VaDriven Mayhem
427 Side oiler with twin paxton S/Cs
Old May 9, 2008 | 09:18 AM
  #48
Sabotage10's Avatar
Sabotage10 has disabled reputation
987 hp / 922 ftlb
3mpg @ top speed
+1, in a Lotus Elise (if it could fit, which it can't obviously).
Old May 9, 2008 | 09:28 AM
  #49
WALL-E's Avatar
WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E
I'm fascinated with amg motors, they just keep getting bigger, and putting out more power. Would be a whore and a half to swap into another type of vehicle though. But hey, I wouldnt mind a e63
Old May 9, 2008 | 09:36 AM
  #50
sidewaysil80's Avatar
Friendly Jackboot
sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80 sidewaysil80
Tomei 296004 S15 SR20DET 2.2 Liter Genesis Complete Engine Phase 2
Tomei Complete E/G SR20DET S15 Genesis Phase 2
Bore X Stroke: φ87.0×91.0mm
Displacement: 2163cc
Piston: TOMEI Forged φ87.0
Conrod: Tomei H-Beam Forged
Crankshaft: Tomei
Camshaft In/Ex: Tomei Poncam Type-R
Head Gasket: Tomei Metal (Bearings)
Valve Springs: Tomei PBB
Rocker Arm Stopper: Tomei
Metal (Bearings): Crank-Nismo / Conrod-Tomei
Conrod Bolts: Tomei H-Beam Forged
Head Bolt Washers: Tomei Strengthened
Oil Pan (Sump): Tomei Larger Capacity Oil Pan
Plugs: Denso Iridium
Thermostat: Nismo
Water Pump: Nissan Genuine
Ornament Plate: Tomei
***All Tomei motors goes through extensive and complete engine work procedures. Procedures include:
Engine disassembly, washing and parts inspection
Dummy head attached for boring/honing
Head balancing
Block surface correction grinding
Crank warping correction and balance (TOMEI perfection)
Connecting rod balancing (TOMEI perfection)
Valve timing adjustment (as for PONCAM adjustment being completed)
Valve clearance adjustment (solid type cam adoption type)
Valve grinding
Seat cutting
Seat ring step attaching correction
Valve set long adjusting
Valve guide upgraded (4G63 excluded)
Compression ratio adjustment
