do engine damper kits help out noticeably
Friendly Jackboot
im looking into this kit, but i dont know if it will be worth it http://www.horsepowerfreaks.com/pric...ne/Damper_Kits
its either that or a performance meter
Re: do engine damper kits help out noticeably
I know that for the rsx alot ot of guys are running the ingals dammper and it help to eliminate some of the wheel hop that the rsx suffers from. When couppled with the energy suspention motor mounts it pretty much eliminates wheel hop all together.
So to answer your question, yes they do help.
If you're worried about wheel hop, stock mounts aren't doing you any favors. I wouldn't bother with the damper until you get some better mounts. You can damp all you want, but the engine will still be flopping around with the stock squishies.
Originally Posted by dirtyjerzusmc
even if im runnin the stock motor mounts? (i know stupid question, im new to this stuff)
