Where's the best place to get wheels road force balanced?
Old May 12, 2005 | 04:40 PM
  #21
Brock Obama's Avatar
Srsly.
Brock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these partsBrock Obama is infamous around these parts
Default Re: Where's the best place to get wheels road force balanced?
isn't the purpose of balancing to equal out any irregularities? So what if the tire is heavier on one side if you counter act that with wieght on the other side of the wheel. I don't understand why this would make a difference.
Old May 12, 2005 | 04:56 PM
  #22
Dash Fieldpaint's Avatar
Dash Fieldpaint is on a distinguished road
Originally Posted by Cobra4B
my remote bleeder line for the clutch hydraulics rubbed through the fuel line causing fuel to piss all over the left side header. Problem is the line let go at a Corvette BBQ up on nova.
Corvette BBQ? Like this one?
Old May 13, 2005 | 01:15 PM
  #23
DeepFreeze's Avatar
DeepFreeze is an unknown quantity at this point
Kevin. check PM.
speaking of wheel balancing, ill need it shortly.
Old May 15, 2005 | 09:47 AM
  #24
To0C0oL's Avatar
squad up!!!
To0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud ofTo0C0oL has much to be proud of
There is a differnece to just balancing the irregularities of the tire and rim to "Matching" the irregularities of both the tire and rim. The more weight you have on a tire, the more likely it is to vibrate at higher speeds. Road Forcing is not nessecary (sp?) for regular highway/street driving unless the irregularities are way too far apart. You cant actually make vibrations from "small" flat spots go away if you can match the rim and tire up perfectly or near perfect.
shawn22
Jun 23, 2007 09:13 PM
S13wannabe
Apr 10, 2005 03:36 PM
