OMG It's hot out there!
Originally Posted by MORE IMPATIENT
get a new pipe, and reroute the dump tube or use some heat wrap, i had a/c in my turbo teg, both times so i know what your talking about with the pipe being so close, but its definitely doable....just take a couple hours and do it, you wont regret it. its like winning the lottery when i turn that thing on when i cant take the heat anymore.
Originally Posted by jentegraGS-R
it had heat wrap on it...the only thing that would work is if i reroute the dump tube which will be a mission...but yeah i'd love me some cold a/c right about now
I don't know your setup at all, but my wastegate(the shroom) part is hitting my top a/c line. It's not the heat thats killing mine.
My friend just got a bracket made, and had it loop around the a/c lines, and he pulled on it, and bolted it down to another bracket he made. It looks pretty good. (It's a turbo Type ARRRRRR!!!!)
O. And I love not having to turn off the a/c to over take someone. Just hit boost.. and bye bye
I work in the diesel shop at NNSY and when we run the diesels for testing it is usually 100 under the vents and 150 next to the engine. This weather is just incomfortable. I am used to the heat, I keep the AC in my house set at 80 and sleep with a blanket.
