Need help (DSM)
Re: Need help (DSM)
Originally Posted by Spindrift187
^ that bbq
-Citium2012 (Chris)
-Citium2012 (Chris)
RIP Chris Schader
Re: Need help (DSM)
i already did a full pressure test. kron1c, thanks but i already found a bov to swap out, and i'm pretty sure thats not it. I've changed the throttle body / intake mani, all vacuum lines a couple couplers put a t-bolt clamp on the weak spots, check all the piping and still nothing
Home, finally
Re: Need help (DSM)
I doubt this would be it, but you think there'd be any leaks in the weld job on the intake mani? No exhaust leaks right? I don't recall hearing any. I've heard of cracked compressor housings as well... ever pin point that faint hissing I/we heard at Leo's that night, near the firewall?
Re: Need help (DSM)
Yeh. When i extended the brake booster line and tightened it down that hissing went away. I'm pretty sure the turbo is done. I've replaced / changed everything else.
edit: I've been waiting for an excuse to get a new turbo anyway. So much for hitting 11's on the 16g but oh well.
Re: Need help (DSM)
did that too. even swapped maf's / filters out. I'm pretty sure it's the turbo. How bout I get you that manifold, and get your 4 bolt 02 flanged cut / welded, to make this deal go thru? I'll even help you take the old one out / install the new setup. Are you going to be using the same wastegate?
psycho jungle cat
Re: Need help (DSM)
-Citium2012 (Chris)
