cutting springs
Old Jun 18, 2003 | 01:34 PM
boodussi808's Avatar
ThanXz_FukYuVeryMuch
boodussi808 has disabled reputation
Also you WILL NOT pass state inspection if you cut it...
Old Jun 18, 2003 | 02:37 PM
IC x Prince's Avatar
IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince
Originally posted by Amerinamese
i have tein s-tech springs on my car and they work fine. and you don't need to mess with camber until you drop your car more than 3 inches. mine dropped 2 inches and i didn't have to change the camber
well i got tein threaded body HE winding master drift spec...and I still cut 4 coils.
Old Jun 18, 2003 | 05:00 PM
Neo Xian Wu's Avatar
Dont Be Scared Homie
go for it man... be cheap, cut the springs... but don't come cryin to the board when your shit bottoms out... jus send pics when your shit is sittin on the ground or you get bounced outta the roof... one or the other would be good... preferably sumthin i could put on my desktop
Old Jun 18, 2003 | 06:16 PM
conspire's Avatar
LOOK-OUT!!1
conspire is an unknown quantity at this point
If you decided to cut them, take 'em off and do the calculations for how much to cut off for the spring rate you want. Don't just try and eyeball it and cut them off while they are on the car (however this does work and saves time), there is an actual formula for this whole procedure.
Old Jun 18, 2003 | 07:37 PM
eng's Avatar
eng
Administrator
eng eng eng eng eng eng eng eng eng eng eng
Default Re: cutting springs
Originally posted by lookatmy6
i was wondering if there is anyone out there that can cut my springs for me?
I got a real nice hacksaw in my garage. You should come by.
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Old Jun 18, 2003 | 07:46 PM
Flite's Avatar
HHIC
Dude, chopped springs are the schizznitt yo! ! Cut them fuckers up yo. Yo whip will be off the chains B.
Old Jun 18, 2003 | 07:50 PM
ECR's Avatar
ECR
Bow Down
ECR is on a distinguished road
my boy heated his springs and it isnt that bad of a ride. not bumpy at all. if any its a smooth bump
Old Jun 19, 2003 | 05:06 PM
NIC668's Avatar
Ok I didnt read all of this thread but if you cut your springs you will need to get a camber kit..because your alignment is set for your ride height.
Heating your springs is stupid..the twist and sag after awhile
Cutting them....again dumb. You cut them you get a shitty ride.
Old Jun 19, 2003 | 07:12 PM
i'm glad someone agree's with me...cutting 1300 springs are the shit...
the winding master. =)
Old Jun 19, 2003 | 08:03 PM
jeremy's Avatar
EMF S2K
jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy
i think you can safely cut all but one coil and still be safe. that damn car would be sooo sexxy.cuttn springs is the dopeness.
