honda accord f22 oil pump replacement
Old 08-20-2009, 01:18 PM
Whatever it takes
ls/vtecstitch's Avatar
ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch
Default honda accord f22 oil pump replacement
I'm replacing the oil pump in a 93 accord and cant get the sprocket off the motor. Its located right behind the water pump. there is a bolt holding it on but i cant get the pulley to stop spinning.
Its #4 on this diagram
ls/vtecstitch is offline
Old 08-21-2009, 07:11 AM
Whatever it takes
Default Re: honda accord f22 oil pump replacement
got it. for those that didn't know there is a service hole on the back of the block towards the pulley. once you remove the bolt covering this hole you need to stick something in there (i used a screwdriver) to stop the sprocket from spinning.
Audio
Engine / Exhaust / Drivetrain
13
03-17-2009 09:28 AM
simplsi
Want to Buy / Trade ARCHIVE
11-01-2007 04:14 PM
Quick Reply: honda accord f22 oil pump replacement
