Temporary wheel spacers! ($30 shipped)
Old Sep 17, 2020 | 09:23 PM
Maiku's Avatar
Maiku is an unknown quantity at this point
Default Temporary wheel spacers! ($30 shipped)
Do you need some wheel spacers but don't know what size you need? Don't want to eyeball it?I designed, printed, and tested these temporary spacers out so you can order the appropriate metal spacer required!
As noted on the face of the spacer, these are not intended to be used while driving EVER! They'll be made strong enough to bolt on the car and drop it on the ground for visual observation only and I cannot recommend EVER driving the car with these on.
!!!!!!!!!!!THESE WILL MELT UNDER BRAKING HEAT AND YOU WILL DIE YOU HAVE BEEN WARNED! PLEASE DO NOT DRIVE YOUR CAR WITH THESE INSTALLED I CANNOT BE HELD ACCOUNTABLE FOR YOUR DECISION TO DO SO AND THE DAMAGES/INJURIES THAT WILL MOST LIKELY OCCUR WILL NOT BE MY FAULT!!!!!!!!!!!!
Colors will be random but different per size
Sizes included are as follows (comes as a complete set):
1x 1mm
1x 2mm
1x 4mm
1x 5mm
1x 8mm
Allowing 1mm-20mm spacing checks
Lug patterns:5x100, 5x108, 5x112, 5x114, 5x114.3, 5x115, 5x120, 5x120.7
78mm center bore and 160mm outer diameter
All lugs oversized to 14mm, may fit other bolt patterns!
Mike.King.2590@gmail.com for paypal! Put your name and address in the notes or I'll have to contact you which will delay the order!
Attached Thumbnails Temporary wheel spacers! ( shipped)-20200918_003805-1-.jpg   Temporary wheel spacers! ( shipped)-20200918_004547-1-.jpg   Temporary wheel spacers! ( shipped)-20200918_011808.jpg   Temporary wheel spacers! ( shipped)-20200905_154137.jpg   Temporary wheel spacers! ( shipped)-20200905_162404.jpg
HondaTwinCam
Suspension / Brakes
Sep 4, 2012 06:07 AM
Bustitsideways
Dec 29, 2009 03:01 PM
