dsm help
Old May 25, 2007 | 05:27 PM
IntegraXSi's Avatar
EtHuGn' N dA NoKe!!!
IntegraXSi is an unknown quantity at this point
Default dsm help
I'am driving my car one day and it just dies, get it home and have no spark. Change out plugs, wires, and check the coils. I had the caps on the ecu replaced about a year ago, and now I think i have acid damage to the board.
So I was wondering if anyone local had a 1g ecu I could barrow to test or buy outright.
BTW: This is for a Galant VR-4
Old May 25, 2007 | 05:37 PM
jdawgs92ludesi's Avatar
jdawgs92ludesi has disabled reputation
Default Re: dsm help
have you called a salvage yard yet? just a thought
Old May 25, 2007 | 06:05 PM
IntegraXSi's Avatar
yeah I called just about every one in the phone book
Old May 25, 2007 | 06:38 PM
連続注入's Avatar
Dont guess, diagnose
連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入
My neighbor has one. Ill have to get with him on it. The car is at my house too
Old May 25, 2007 | 07:22 PM
KoticOne's Avatar
KoticOne has disabled reputation
my car just stopped turnin on 2 days ago... im tryin to figure out whats wrong with it... the caps look fine... shes gettin spark but wont start
Old May 25, 2007 | 08:09 PM
連続注入's Avatar
well if spark is good then your other quick option to check is fuel.
Old May 25, 2007 | 08:28 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
if it lost spark then it most likely lost injector pulse also, check it. its one of a few possible things: bad power transistor (aka ignitor or ignition module) [most likely], dead coil pack (doubt it), mpfi fuse, ecu damage, mfi relay, cam angle sensor.
Old May 26, 2007 | 02:56 PM
KoticOne's Avatar
messed around with the fuel pump relay today and she started.... but only with 2 cylinders so now im tryin to figure out how to get the out 2 workin... all cylinders gettin spark but no fuel i beleive
Old May 26, 2007 | 03:11 PM
g S x's Avatar
RIP Chris Schader
power transistor, its on the drivers side of the intake manifold under the coil pack. you probaly need a new one.
Old May 27, 2007 | 05:17 AM
KoticOne's Avatar
does that control the injectors?
