zex installation help
corona connessuer
Re: zex installation help
Originally posted by BlackSRT4
where is a common place to find the throttle sensor position wire?
Bitches get Stitches
Re: Re: zex installation help
Originally posted by sk8rmike
it will be going to a plug somewhere on the throttle body. i am unsure of where on the throttle body it will be because i've never worked on an srt4. you can test with a condinuity tester by pulling out the plug and seeing which pin in the plug reads .5 volts at no throttle and 5.0 volts a WOT.
Blacksrt4 are you on srtforums.com. He lately there has been a bit of none technical stuff on there but there are still some great info there. If you do a search there is a wiring diagram. Also do you have the repair manual? It's only $20 or so for the main srt-4 one. If you need any more info out of the manual let me know and I'll see what I can do.
Oh yah let us know what you think about the Zex kit. Clay of blackdog motor sports seems a little leery of the new zex kit with the brain in a box so I'm thinking about doing a NX setup.
well you should see my installation, i love it. you cant see anything beside the fuel line coming off the fuel rail. the brain box in mounted on the bottom of the stock airbox(very hidden). everthing is sleek and clean, the motor still looks stock and with every mod i do its gonna look that way. right now with 17-18 psi and the sprayin im guestimating that i should be around 310-320 at the wheel.
