zc crank problem
zc crank problem
so this is really pissin me off. my crank is not spinnin as easy as it should be. i took the last 3 pistons out, cause with the last one while i was taking them out, it would spin. i put the next one in, and now its back to not spinning. i tried switching each connecting rod with it, but its not doin shit. shoulda kept them in order when i took it apart its a obd0 nonvtec zc with new d16a6 piston rings and new d16a6 bearings. (other stuff was here)
This post has been edited by the moderation staff.
RIP DRAGVA-2016
Re: zc crank problem
you forgot to quote him
Go to local auto parts store. Ask for plasti-gage (green). Look on google for instructions of how to use it. Clearance each bearing. If it worked before disassembly, with enough time you can figure out the reassembly configuration. Zip Loc bags and a Sharpie marker during disassembly will save you from this next time.
RIP DRAGVA-2016
i pooped a squirrel
