wtf someone explain this
Re: wtf someone explain this
Originally Posted by dipset-racing
ha ha ha..."Juelz Santana races" no dumbass its a team.
team leaders car here: http://octaneonline.com/rags2riches.htm u probly seen it in octane awhile back, read the decal on the windshield.
Sumospeed #O.G.
Originally Posted by SlowLS
That car is rather ugly looking to be nice. Also why would you completely jack someones name and clain it as your own. Thats even worse than team V-TAK
I1II1I1
i use to have a 3 stage vtec in a 96 civic, it was a d15 3 stage and if ayone knows me they can vouch seeing it. it had 2 vtec selinoids(sp) bought it off of ebay for super cheap guess no1 knew how to hook it up but i just ran it with the ex y8 ecu and never had a problem and when the top end vtec kicked in when all valves were open it sounded like a b-series u could hear it big time. there is also a article about it
http://www.leecao.com/honda/vtec/3stagevtec.html
Originally Posted by Fabrik8
By the way, I never knew stainless brake lines give better stopping power.. The BS is all over the place.
Originally Posted by DryHopSux13
So if your in dipset, you must know my boys Reggie with the blue ls/vtec hatch and Calvin with 92-95 swapped gsr hatch.
Sumospeed #O.G.
How I jack sumone else's name? I know the people on the team and hang with the ones that are still in school.
reggie not with DSR(Dipset Racing) and he dont got the blue hatch no more he sold and now he gotta black del sol. and i dont know nobody named calvin but if ur talkin bout a guy that got a 92-95 black hatch with sum gsr rims his name not calvin. how do u know about DSR?
Originally Posted by 88CRXHFBSTNG
actually they do. stainless does not expand or bulge under pressure like rubber can. They require less pressure to operate at there maximum potential which means more stopping power,
They require less pedal pressure, not less fluid pressure. All the stainless lines improve is pedal feel and modulation. You can't boost the power of a hydraulic system by changing to a less flexible line, actuation pressure is actuation pressure. It doesn't matter if a line expands a little under a 'X' pressure, the fact that you have 'X' pressure means that you're going to have 'X' pressure worth of actuation force. If the line is stainless and doesn't expand at 'X' pressure, you still have the same amount of pressure. The only thing that changes is the amount of fluid displacement that is lost in the line expansion. For example, it's like saying that 1000 PSI with stainless lines is a different amount of actuation force than 1000 PSI with rubber lines. 1000 PSI = 1000 PSI, what happened to your argument?
IF YOU HAVE the right components to go with it like bigger rotors, mulitiple potted calipers and the right pads.
That's like saying that your cold air intake will make 40HP, if you have the engine swap to go along with it.
