wtf!!!! loose timing belt
Old 08-28-2009, 12:30 PM
bLu92bUbbLe's Avatar
bLu92bUbbLe has disabled reputation
Default wtf!!!! loose timing belt
when i put it on...it was nice and tight....but once i started the car it got loose and flabby....can this be the reason from 1-3k rpms the shit feels like it doesnt wanna go anywhere...then it picks up like a beast after that
bLu92bUbbLe is offline
Old 08-28-2009, 12:35 PM
vxcoastie's Avatar
vxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to all
Default Re: wtf!!!! loose timing belt
you have to turn the motor a couple of revolutions before you tighten the tensioner.
vxcoastie is offline
Old 08-28-2009, 12:38 PM
やくざに成りたい
atmdc's Avatar
atmdc has disabled reputation
I wouldnt be driving it like a beast if I were you with a loose timing belt, or your going to be walking like a beast
atmdc is offline
Slammedxpert
SortaFlush's Avatar
Do not drive it like that anymore. Your not having the correct tension on the timing belt. Try again.
SortaFlush is offline
Old 08-28-2009, 12:59 PM
question...i was told never spin the crank clockwise....not even to line up the bottom 1st???? could this b why
Old 08-28-2009, 01:00 PM
Originally Posted by atmdc
I wouldnt be driving it like a beast if I were your with a loose timing belt, or your going to be walking like a beast
yea...id be sooo fukn tight...i just rebuilt this shit...lol i think i would just sell everything and get a benz or sumthin...
Old 08-28-2009, 01:09 PM
civickid03's Avatar
civickid03 has disabled reputation
take the lower timing cover off and check to see if everything is still aligned.
if everything is good loosen the tensioner a turn or two until its *slightly* loose.
turn the crank counterclockwise about a quarter of a turn (maybe a lil more).
when your turning the crank cc check the amount of tension on the left side of the belt and at top of the camgears - as you turn the motor the slack in the belt will be moved - when the slack reaches the tensioner pry up a little on it while u tighten it the last turn. turn the motor over 2-4 times and make sure the tension is in the right spot and the left side of the belt isnt loose. thats it ur done it takes about 1.5 hours
civickid03 is offline
Old 08-28-2009, 02:20 PM
cash paid to the person in richmond that lines this shit up right....erything is off....im fed up...tooo much play n the damn belt...
Old 08-28-2009, 02:38 PM
Slammedxpert
SortaFlush's Avatar
Do you have a mini me/ls vtec or any mismatch shit? It could be the wrong belt..
Old 08-28-2009, 02:56 PM
gsr block...b16 head....gsr belt right
Quick Reply: wtf!!!! loose timing belt
