Wheel bearing...need help!
I need to replace my wheel bearing and I am not sure how to do it. I was told that I need a bearing puller, so I went to auto zone to try and get one and they were confused on what I needed it for. So, if any of you would like to help me out, I would appreciate it. I have already bought the $70 wheel bearing and it's just sitting in my car.
I need to get this fixed soon, because it's getting really loud and bad, very quick.
Re: Wheel bearing...need help!
maybe he ment that its a pressed wheel bearing, in that case you need a shop press. if you want me to do it for you i have a press at my disposal
just to clear things up is it a bearing on the rears or the front, the front needs to be pressed outfrom the front throught the back note(remove snap ring) if it's the rear it just bolts off, if the inner race from the hub stays on the spindle, remove backing plate and get a chisle and try to pry race from spindle with hammering the chisle in between the two( try not to scar the spindle)
