-   -   what is wrong with this ?? (https://www.vadriven.com/forums/tech-talk-9/what-wrong-145020/)
StuntinOutlaw Jun 26, 2006 10:38 AM
i tried doing the s14 electric fan install but the fan doesn't turn on...i dont know why....the fan works with it connected straight to the battery but i connected it to a good ground and i took the blue/green stripe wire out and put the fan wire....and nothing...and i left the car running for about 10-15 mins....what do i do ?
Spindrift Jun 26, 2006 10:49 AM
Re: what is wrong with this ??
(im guessing you mean the stock e-fan) So you're trying to get it to run full time im assuming?
(F-) Jun 26, 2006 10:51 AM
any luck jake??
(isuckyodick!!)
StuntinOutlaw Jun 26, 2006 10:52 AM
yea the stock e-fan on the sr20det...and no im not trying to make it run full time....just when it need to turn on it does and when it doesnt it turns off...i dont want to burn it up
MerF Jun 26, 2006 10:55 AM
Try turning on the A/C (even if you dont' have it, the ECU is supposed to kick on the fans for extra cooling when the A/C is running).
At least that's in most cars, I don't know about the dorifto-master nissans. ;)
aacjohnc Jun 29, 2006 08:17 AM
check the fan relay box ?
slo_rex Jun 29, 2006 02:11 PM
let me explain there is a thing called a temperature switch and it will not engage the fan until it hits a certain temperature so let it run til it gets about normal and then see if it will cut on if not check your wires and that switch
Spindrift Jun 29, 2006 03:09 PM
O dont know about that, I always make em run off an ignition source. Again I end up being useless lol
Slepping_H22_DC Jun 30, 2006 10:41 AM
actualy its a thermoswitch :thup:
drive car around town first then idle for 10minutes if no joy then
check your relay and thermoswitch. If you said it working hard wired there is nothing wrong with the fan at all.
