what is wrong with this ??
i tried doing the s14 electric fan install but the fan doesn't turn on...i dont know why....the fan works with it connected straight to the battery but i connected it to a good ground and i took the blue/green stripe wire out and put the fan wire....and nothing...and i left the car running for about 10-15 mins....what do i do ?
Originally Posted by Spindrift187
(im guessing you mean the stock e-fan) So you're trying to get it to run full time im assuming?
Try turning on the A/C (even if you dont' have it, the ECU is supposed to kick on the fans for extra cooling when the A/C is running).
At least that's in most cars, I don't know about the dorifto-master nissans.
let me explain there is a thing called a temperature switch and it will not engage the fan until it hits a certain temperature so let it run til it gets about normal and then see if it will cut on if not check your wires and that switch
Originally Posted by StuntinOutlaw
yea the stock e-fan on the sr20det...and no im not trying to make it run full time....just when it need to turn on it does and when it doesnt it turns off...i dont want to burn it up
drive car around town first then idle for 10minutes if no joy then
check your relay and thermoswitch. If you said it working hard wired there is nothing wrong with the fan at all.
