what is the best motor
Old 11-23-2008, 06:24 PM
acuraman2012's Avatar
acuraman2012 acuraman2012 acuraman2012 acuraman2012 acuraman2012 acuraman2012
Default what is the best motor
i have a 97 integra it has a b16 block and ls head. i want to make it a full type R but b4 i spend some money i want to know if there a better motor that i can put it.
acuraman2012 is offline
Old 11-23-2008, 06:30 PM
Digital Life
83Stang5.0's Avatar
Default Re: what is the best motor
I'm in no way a fan of B series, but from what I'm aware of, B18C5(ITR) is just a slightly higher compression motor. If you want to do a ITR replica, C5 would make good power and more then what you have now.
If you are worried about bang for your buck, you could definitely build an equally fast(if not faster) motor combo for the price you'd pay for a real B18C5. Try to get a quote, then compare it to how much you could get for parts or a different B series.
83Stang5.0 is offline
Old 11-23-2008, 06:37 PM
i could do that but i was not sure if i could get as much hp as a full type r. and i did not know if there is a better motor then a b18c5 for integra
Old 11-23-2008, 06:51 PM
Keeping It Real !!
ravenracer's Avatar
ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer
what are your plans ? what do you want to do to the engine .. think about all that and go from there... Higher compression boost is less of an option... then go na ... lower compression = i love boost
gsr head, ls bottom maybe
ravenracer is offline
Old 11-23-2008, 07:17 PM
ok so if i can boost it up and make it faster then a b18c5 for less the money thats what ill do. but do you think it would be better for me to buy a gsr motor and start from there?
Old 11-23-2008, 07:19 PM
92 si hatchy
jdmsihatch's Avatar
jdmsihatch has a little shameless behaviour in the past
k20 swap would be whats up but if u want a bang for buck go with a ls-v or b20v
jdmsihatch is offline
Old 11-23-2008, 07:23 PM
k20 is a civic motor rite?
Old 11-23-2008, 07:25 PM
92 si hatchy
jdmsihatch's Avatar
well it comes in alot of cars. like rsx and civic si
Old 11-23-2008, 07:31 PM
ok. because what im doing is.. im about to fix up my teg but idk to much about it. so i want to get a top of the line motor or just find out what i should do to it as far as that goes
Old 11-23-2008, 07:35 PM
Fanboi
Cobra4B's Avatar
LSX
/thread
Cobra4B is offline
Quick Reply: what is the best motor
