wet spark plugs in an sr20det. need advise
Old 11-26-2007, 08:06 AM
camelsx's Avatar
camelsx has disabled reputation
Default wet spark plugs in an sr20det. need advise
ok...i have white smoke out my exhaust(fuel problem?) and also have two cylinders not firin. lets call the two not firin 1 n 2 and the other two 3 n 4. the problem is that the spark plugs from 1 and 2 are wet killin the spark. even when i switch the spark plug out of the #3 and #1, cylinders 1 and two still do not fire, and come out wet. whitch made me rule out bad spark plugs. i did the same to the injectors and the coil packs. same result. what do yall think. Im all out of idea. appritiate any feed back. thanks. and if you have no advise or even if you do and know a shop that works on jdm motors in the hampton rd area that could help too. again thanks
camelsx is offline
Old 11-26-2007, 08:12 AM
murphy660's Avatar
murphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these parts
Default Re: wet spark plugs in an sr20det. need advise
LOL wet with.....? coolant? oil? fuel?
sounds like a blown headgasket...
2 cylinders not 'working' and white smoke.
murphy660 is offline
Old 11-26-2007, 08:17 AM
corona connessuer
CHAHONDA's Avatar
yup...that a blown head gasket!
CHAHONDA is offline
Old 11-26-2007, 08:22 AM
camelsx's Avatar
gas
camelsx is offline
Old 11-26-2007, 08:30 AM
camelsx's Avatar
F#@$ how positive that its a head gasket.
camelsx is offline
Old 11-26-2007, 08:40 AM
Shooting 63's
idriveahonda's Avatar
After reading these things = blown headgasket.
White smoke = blown headgasket
Blue smoke = oil
Black smoke = gas
idriveahonda is offline
Old 11-26-2007, 08:44 AM
camelsx's Avatar
not the answer i was lookin for. i guess its head gasket and studs shopin time. thanks. question.........what if my oil is not cloudy?
camelsx is offline
Old 11-26-2007, 08:45 AM
camelsx's Avatar
is it safe to drive. and if it is how far and how hard
camelsx is offline
Old 11-26-2007, 03:42 PM
psycho jungle cat
Spindrift's Avatar
check your injectors and dont ask how long its safe to drive. NOBODY knows.
Spindrift is offline
Old 11-27-2007, 07:37 AM
camelsx's Avatar
its not the spark plug. could it be and ignitor?
camelsx is offline
Quick Reply: wet spark plugs in an sr20det. need advise
