VW engine codes P1582 & P0440
Old 09-13-2010, 01:10 PM
I GOT 5 ON IT
murderrsirenss's Avatar
murderrsirenss has disabled reputation
Default VW engine codes P1582 & P0440
Tried the most common solutions for these, but now im outta ideas. Anyone had these before and gotten rid of them?
murderrsirenss is offline
Old 09-13-2010, 02:00 PM
Default Re: VW engine codes P1582 & P0440
Are those codes mean....?
Old 09-13-2010, 02:05 PM
eyeGOsloo's Avatar
What engine do you have?
P1582 = Idle Adaptation At Limit
Check IAC, MAF and the circuit(s). You could also clean your throttle body to see if that helps.
Not sure about the p0440
eyeGOsloo is offline
Old 09-13-2010, 02:12 PM
eyeGOsloo's Avatar
Found this on vwforum
A code P0440 could mean one or more of the following has happened:
* The gas cap is not installed or working properly
* The purge solenoid has failed
* The canister is plugged and not working properly
Possible Solutions
With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
* Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
* Inspect the EVAP system for cuts/holes in tubes/hoses
* Inspect for damaged or disconnected hoses around the Evap purge solenoid
* Check and/or replace the sensor
* Check and/or replace the purge valve
* Have a professional use a smoke machine to detect leaks
jimporsche86
04-01-2004 03:53 PM
NRG_RSX
03-18-2004 06:11 PM
Carter
05-22-2003 07:07 PM
CRXtacy
05-15-2003 07:31 PM
Quick Reply: VW engine codes P1582 & P0440
