vtec oil pressure and engine temp
Is in ur head, why?
i have a an obd0 b16 engine and i want to know how much oil pressure is needed before vtec will kick in (in psi's). and how hot does the engine have to be for vtec to kick in. (degree's farenheit).
hybrid no more :(
Re: vtec oil pressure and engine temp
not too sure about oil pressure but I think it's 57psi. As for coolant, you motor needs to be warmer than 110F. Just a FYI, the other 2 variants are speed 20mph and RPM 5300rpm (stock ecu). HTH
