Turbo LS DA wont start. Please Help!
Old 07-23-2012, 07:08 AM
amb
amb's Avatar
amb has disabled reputation
Exclamation RESISTOR BOX HELP!! WHAT TO DO IF STOCK HARNESS IS GONE
Okay, I have a 92 Integra. I just finished doing the turbo set up. Has 450 dsm's, i read a write up on resistor box install and thought i did it right. Attempted to start car and it acted like it wasnt getting fuel... I took a look at a different write up for the box and it appears that i fucked it up pretty good. I clipped all the wires going into that stock harness that doesnt go to anything and i no longer have it. What do i do now that i dont have that stock clip? Also, do i need to worry about the ecu being messed up from when i attempted to start it? Sorry if all thats kind of vague, i figure you will ask the questions you need. And please keep the insults to a minimum lol i realize i fucked up
amb is offline
Old 07-23-2012, 08:13 AM
Fence Hopper
Alkaline8214's Avatar
Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214 Alkaline8214
Default Re: RESISTOR BOX HELP!! WHAT TO DO IF STOCK HARNESS IS GONE
Wire it up yourself and make it look as professional as you can.....get another clip from a junk harness.
yeh...u did fuck up lol. Good luck bro. Put it back like its supposed to be and let someone else do it
OR BETTER YET,
Just get that someone else to do it NOW lol
Alkaline8214 is offline
Old 07-24-2012, 10:05 AM
amb
amb's Avatar
Exclamation Turbo LS DA wont start. Please Help!
Okay, this is the 2nd thread ive made regarding this but am hoping i get more hits by rewording it. I have a 92 Integra. I will provide you with a list of mods and as much possible information about the car as I can in order to weed out a lot of the first assumptions on what the problem may be.
INFO; The car has 220k+ miles on the body, it has a stock LS motor and trans with about 85. Modification wise it has a walbro 255 lph, Stainless turbo mani, 2.5" DP back exhaust, t04e turbo, civic half-sized radiator, set up running no ic with 2" charge piping. 450 dsm's with resistor box, ngk bkr7e's.
So what happened was I had boosted the car, got it tuned and kept having boost problems so i took all the shit off. When i did this i left the chip that was in my ecu in and i simply clipped the j1 jumper in order to negate its effect. Okay so i just put a different kit (same specs just new parts) on the car and resoldered the j1 jumper in my ecu. I also rewired the resistor box because apparently when i did it the first time, it was done incorrectly (possibly one of my boost problems) now i have everything installed in the car but it wont start!
Seems like to me that it is not getting fuel, it turns over and over but no fire. I checked spark and its fine. And that walbro fuel pump is loud as shit so i know its turning on.
ANY THOUGHTSSSS!!!???? PLEASE HELP!
Attached Thumbnails Turbo LS DA wont start. Please Help!-558374_4401198594258_405071729_n.jpg
amb is offline
Old 07-24-2012, 02:04 PM
D15b1>k20a
kf91da9's Avatar
kf91da9 has disabled reputation
Default Re: Turbo LS DA wont start. Please Help!
i offered my help already.. i guess im not good enough..
kf91da9 is offline
Old 07-24-2012, 02:43 PM
I merged the threads. There is no need to make two.
Old 07-24-2012, 07:52 PM
00_civic757's Avatar
00_civic757 has disabled reputation
fix the wiring that u cut and then convert it to obd1 dude and loose the resistor box all together
00_civic757 is offline
Old 07-25-2012, 02:10 AM
Fence Hopper
Old 07-25-2012, 03:01 AM
The ECU has nothing to do with it, its all about the injectors and the dsm injectors need a resistor box.
Old 07-29-2012, 02:26 PM
Dickbutt #peentip
Kris.Is.Foamin's Avatar
Because you're a cheapass with shitty parts and halfass methods.
I wish dumb honda fucks would stop ebay building and ghetto rigging their cars.
I'll get it running for you. $60 an hour till it's done plus the CORRECT parts to properly build it.
Kris.Is.Foamin is offline
Old 07-30-2012, 06:23 AM
Whatever it takes
ls/vtecstitch's Avatar
ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch
If you like i can help out. I dont mind coming by and taking a look. Just shoot me a pm.
ls/vtecstitch is offline
Quick Reply: Turbo LS DA wont start. Please Help!
