Trying to work on a list of parts on the car..
Old 04-11-2003, 01:28 PM
You name it I got it
93foxbody's Avatar
93foxbody is an unknown quantity at this point
Default Trying to work on a list of parts on the car..
Man its hard to remember all this shit. Oh well for who ever cares to look.
MODIFICATIONS TO 93 GT
SUSPENTION
Hal Fully Adj. Rear shocks / Torque boxes. Some welding
Hochkis upper-lower control arms(removed quad shocks)
QA1 K-member
Hal / QA1 Coil Over front suspention n Fully adj.
HAL A-arms
M. Motorsports Caster Camber plates
Hal Fully adj. Struts
Flaming River Steering rack
Flaming river Polished alum. steering shaft.
bump steer kit
All new bushings
CHASIS & DRIVE TRAIN
Motorsport 3.73 gear
Pro 5.0 shifter
Anderson High Rev Clutch
L:akewood Scattershield Bellhousing
lightweight Alum Flywheel
Eaton center unit
Strang axles
C-Clip Elimanators
Tremmec 3550
BBK adjustable clutch quadrant
Motorsport aluminum drive shaft
MOTOR
D.S.S. 306 Pro bullet
Twisted Wedge pistons
Anderson Race Preped
Vortech S-trim w/14lb pulley
Vortech Mondo Bypass Valve
Anderson Power pipe
Acufab 70mm throttle body
Pro-M 77mm MAS
Acell 8.8 wires
Coustom Ground Cam
Trick Flow Upper@ Lower Intake
over 1000.00 in portmatching and worked to death..
1/2 inch upper intake spaver acer
Foxlake Trickflow ported & polished heads(alum., beefed up) Compression more than you think..
all good internals, been milled and port matched to intake, flow over 300 CFM.
Crane 1.6 roller rockers
Trickflow pushrods(.6 longer than stock)
Motorsport timing chain
Elderbrock high flow waterpump
March underdrive pulleys(chrome)
Billet smog pump delete kit
ARP Bolts through out.
Fluidyne 3 core aluminum radiator
Short belt (best buy)
Air Conditioning
130 amp polished 1 wire alternator
D.S.S Stud Girdle
FUEL SYSTEM
Cartech Stage 3 Fuel system
Vortech FMU
Vortech Fuel Rails
87 LBPH Injectors
VP 116 Fuel always!
EXHAUST
Bassani 1 3/4 - 1 7/8 stepped LT headers
Bassani 3" X-Pipe
Bassani Quiet Thunder 3" mullers@Tailpipes
No cats
all Jet Hot Coated
ELECTRONICS
E.P.E.C. Extreme Performance Engine Control (SVT)
with complete stand alone mode no stock computer!
operated with lap top only.
Crane HI-6 Ingition and coil.
2 step rev limiter
Data logger.
Tach, boost, fuel press, oil press, temp gauges, 2 EGT sensors @display
SOUND SYSTEM
Sony cd head unit
Kicker amplifiers
JL Audio w-6 10 in. sub-woofers(2)
5th order ban pass plexe glass i glass
Eclipse speakers all around
OTHER
R1 Racing seats
5-point Harnesses
8 Point Wolfe Craft Roll Cage.
Brand new interior ( carpet molding weatherstriping etc )
Stanless stell relocated battery to rear
Optima Yellow top battery
all new wiring ( 1 gauge power wire )
Power shut off switch
Kenny brown Double diamond sub frame connectors.
Drive shaft safty loop
all kind of crome accesories for dress up.
Idle air bypass valve delete plate billet aluminum.
INFO ON CAR
Two tone (green-titanium)
Stock in appearance
SLEEPER
R8D-XXX plates
bought in Nov-99
paid 7800.00
EXPECTED PERF, PERFORMANCE
500-600RWHP
10.0-10.9 ETS.
130-135MPH..
Cost w/out car in parts, machine work and some labor 29,660.00
And alot of other shit I forgot Im SURE!!!! LOL....
93foxbody is offline
Old 04-12-2003, 09:42 AM
93foxbody's Avatar
also got a log of all my old time slips LOL what a joke but its fun to see how far it come. Dont have last 4-5 slips on there need to update. Obviously I have some time at work.
RICHMOND RICHMOND Virginia Motorsports Park
4-0-00 4-00-00 8-25-00
R/T= .826 R/T= .772 R/T= 1.314
60'= 2.052 60= 2.123 60'= 2.015
1/8TH= NA 1/8= NA 1/8TH= 8.390
1/4= 15.604 1/1= 14.225 1/4= 12.932
MPH= 86.2 MPH= 98.46 MPH=109.24
4-00-00 4-15-00 11-10-00
R/T= .767 R/T= 1.154 R/T=1.169
60= 2.263 60'= 1.920 60'= 1.787
1/8= NA 1/8TH= NA 1/8TH= 8.257
1/4= 14.751 1/4= 13.047 1/4= 12.919
MPH= 94.93 MPH= 108.17 MPH= 106.09
RICHMOND Virginia Motorsports Park Virginia Motorssports Park
4-00-00 8-25-00 11-10-00
R/T= .889 R/T= 1.189 R/T= 1.099
60= 2.112 60'= 2.048 60'= 1.683
1/8= NA 1/8TH= 8.459 1/8'= 8.165
1/4= 14.231 1/4= 13.014 1/4= 12.871
MPH= 96.98 MPH= 108.99 MPH=105.25
Its not coming out right on computer?? transfered from works.
Old 04-12-2003, 10:21 AM
nickyroo's Avatar
nickyroo is offline
shaggy240sx
12-27-2008 05:42 AM
(mophead)
Want to Buy / Trade ARCHIVE
07-29-2007 08:43 PM
93foxbody
01-03-2003 03:52 PM
Quick Reply: Trying to work on a list of parts on the car..
