Transmission replacement.
Old 11-30-2009, 10:05 AM
cleanEK's Avatar
Default Transmission replacement.
I have a Civic with a B20b in it, with a LS transmission. 3rd is starting to go out (popping out and such) if I decide to replace it with a b16 or GSR trans would I need to change my clutch to work with the different trans?? Same with the axles? Since the flywheel/clutch/axles are not even a year old, I would really like to not have to buy them again lol.
cleanEK is offline
Old 11-30-2009, 10:16 AM
JAY SPEC
00civichatch's Avatar
00civichatch 00civichatch
Default Re: Transmission replacement.
Nope. All the same. Where are you located? I can fix your old trans cheaper than you buying a new one.
00civichatch is offline
Old 11-30-2009, 10:24 AM
cleanEK's Avatar
I just got stationed in Whiteman AFB, Missiouri. So to answer your question about 18 hours away lol.
So everything is the same, sweet.
cleanEK is offline
Old 11-30-2009, 12:52 PM
psn u sdwyz n slo ln
slowz06's Avatar
slowz06 has disabled reputation
Instead of replacing the transmission why don't you check the synchros and shift forks.. could possibly be much more cheaper, especially if you know how to turn the wrenches, (but more time consuming) than buying a new transmission.
slowz06 is offline
Old 11-30-2009, 12:53 PM
Sorry. Not really.
BentValve's Avatar
BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve
I agree with the suggestions. No need to replace the whole tranny for 1 gear.
BentValve is offline
Old 12-02-2009, 03:26 AM
cleanEK's Avatar
I would attempt it but i don't know how confident i am at pulling the transmission apart. but thanks i will check it out. thanks for all the input
cleanEK is offline
Old 12-02-2009, 07:08 AM
Brown Water
Livin_Legend's Avatar
Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend Livin_Legend
There are numerous wright up's on this topic. If you have turned a few, should be a good repair. Just keep everything in order when your remove and replace them.
Livin_Legend is offline
homeslice287
17
05-19-2009 05:46 PM
tonic
03-09-2008 07:05 AM
00civicman
02-05-2008 04:19 PM
tiki240
02-18-2006 02:08 PM
Quick Reply: Transmission replacement.
