Ticking Noise in engine
Old 12-20-2004, 12:12 PM
SuMeRbOaRd's Avatar
SuMeRbOaRd is an unknown quantity at this point
Question Ticking Noise in engine
Hey, I have a 93 GSR that had the engine just rebuilt. Around 940 miles from the time it was rebuilt it developed a ticking sound which has gotten louder over the last 40 miles. I changed the oil and filter at 500 miles and was getting ready to do it again at 1000. Any ideas on what it could be? People said check the valve clearance and I did that to the best of my ability but I still couldn't figure it out. It is a modified engine though. The pistons are JE .030 oversided and possibly domed up a little more. The head and valves are all stock. It doesn't sound like it is coming from every cylinder but only from like the top left. Any help on how to check the clearance would be good so I know that I didn't do it wrong as well. Anyone know the exact clearance for the 93 GSR (B17A1)?
SuMeRbOaRd is offline
Old 12-23-2004, 01:01 PM
Currently N/A
EvolutionBoostin's Avatar
EvolutionBoostin is an unknown quantity at this point
Default Re: Ticking Noise in engine
As far as valve clearances, search around on the web there's dozens of tutorials on how to do that. Ticking sounds like it could maybe be piston slap, which happens sometimes with aftermarket pistons.
EvolutionBoostin is offline
Old 12-23-2004, 01:05 PM
hostgator.com
flow fx's Avatar
flow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these parts
my escort piston slaps all winter long
does the sound go awa once hte oil warms up or what?
flow fx is offline
Old 12-23-2004, 07:16 PM
GULLIE's Avatar
GULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond repute
what weight oil are you running?
GULLIE is offline
Old 12-23-2004, 07:26 PM
R E U P Gang
zexpwrd4door's Avatar
zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door
see if it goes away at like 2-3k if so its piston slap....Ive had it before
zexpwrd4door is offline
Old 12-24-2004, 07:18 AM
SuMeRbOaRd's Avatar
Pennzoil 10W-30 is in it now, when I change the oil the time after this I am using Mobile 1 fully synthetic. It has the same sound when you hit the gas, let off the gas, or whatever. It's not really too loud, you can hardly hear it in the car with JUST the heater running wide open.
Old 12-24-2004, 03:14 PM
hostgator.com
flow fx's Avatar
switching to synthetic will probably make it worse
flow fx is offline
all4sr's
03-21-2008 09:25 AM
98 h22 accord
12-03-2007 05:07 AM
pimpinainteasy
08-07-2003 05:07 AM
Quick Reply: Ticking Noise in engine
