Throttle body???
Old 05-17-2008, 07:18 PM
98 civic -rebuilding
zach byrd's Avatar
zach byrd has disabled reputation
Default Throttle body???
Ok I will start by saying I have a D16y8 with a Skunk2 intake manifold. I want to get a throttle body for the intake manifold but do not know what would be best for this setup. I was also wondering what the stock bore for my y8 throttle body is and what bore I should go with? I have heard that the type r would bolt up perfectly and would be a good option. Any feedback would be helpful. thanks!
zach byrd is offline
Old 05-17-2008, 10:17 PM
93turboeg's Avatar
93turboeg has disabled reputation
Default Re: Throttle body???
nothing bigger than a 66 mm.skunk2 manis are 64 mm so going much bigger wouldnt help.
93turboeg is offline
Old 05-18-2008, 02:35 PM
WAT
funnahguy's Avatar
funnahguy has a spectacular aura aboutfunnahguy has a spectacular aura about
not sure of your budget, but if I were you and could put down a little cash, pick up anything cheap that can be bored that big, then send it to maxbore.com with your new manifold and get it portmatched and cleaned up. Check on the site to see what tb's you can use.
funnahguy is offline
eXploited
01-07-2008 06:11 AM
Quick Reply: Throttle body???
