t25?
Old May 11, 2005 | 04:01 PM
MarkiSick's Avatar
Fucks wit it
MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick MarkiSick
Default t25?
whats the stock wastegate on the t25 set at? is it 8psi?
Old May 11, 2005 | 06:09 PM
Spindrift's Avatar
psycho jungle cat
Default Re: t25?
wut t25? SR???(7psi I believe)
Old May 11, 2005 | 06:33 PM
200+hp240sx's Avatar
200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx 200+hp240sx
Default Re: t25?
i dunno on my garret, i guess ill have to find out when i put it on
Old May 12, 2005 | 11:25 AM
MarkiSick's Avatar
Fucks wit it
Default Re: t25?
if its at 8psi.... if there is a manual boost controller on the vacuum line on the wastegate actuator can it be lowered or just raised? thanks sorry,,, new to the boost
Old May 12, 2005 | 05:15 PM
Default Re: t25?
with a manual boost control you can lower it all the way to a pound. but it depend on the waste gate for how high you can set it. its going to be farely low on a t25 but you will have enough to have fun. stay in 10psi and dont get in trouble with the cops
Old May 12, 2005 | 05:26 PM
boostedgst97's Avatar
cubs 4 life
boostedgst97 has disabled reputation
Default Re: t25?
i think stock is inbetween 10-15 psi i ran 10 on my gst stock
Old May 12, 2005 | 05:30 PM
PJ2's Avatar
PJ2
PJ2
Default Re: t25?
Stock on a DSM t25 is spring controlled to 11psi.
Old May 12, 2005 | 05:48 PM
sk8rmike's Avatar
Bitches get Stitches
Default Re: t25?
You are fucking incompetent. Just stop talking. A boost controller only allows you to RAISE boost, not lower it. You are thinking of a wastegate. The stock wastegate on a mitsu T25 regulates boost at 7 psi. The stock level on DSM's is 10 psi, because of how they are built from the factory.
Old May 12, 2005 | 06:30 PM
themacuser.org's Avatar
i got 5 on it
themacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these parts
Default Re: t25?
.. umm.. you don't set anything on any wastegate. The stock BCS or a boost controller (get it - a boost controller - it controls boost - amazing, 'eh?) controls how much boost it runs, and those don't come with the turbo's if you bought one.
.. and yes, depending on the set-up, the boost controller usually allows you to lower boost from the factory boost setting. Not necessarily to zero, but lower than stock. Again, this has nothing to do with the wastegate itself.
Now, if you don't mind, I'd like everyone who has previously replied in this thread to go to your local library and read a book before ever opening the 'tech talk' forum again.
Cliff note - unless the t25 you bought came with a boost controller some some type, it's going to run with the wastegate open until something breaks. In your case, I hope it's something internal and not the turbo itself. That way, you'll get to take an engine apart and maybe learn something.
Old May 12, 2005 | 07:02 PM
PJ2's Avatar
PJ2
PJ2
Default Re: t25?
Dude, assuming that we are all talking about a turbo with an internal wastegate(he said stock wastegate on a t25), if it has no boost controller attached to it, it will stay close untill the exhaust pressure overcomes the spring tension on the wastegate actuator and will then open the wategate. It willl not run open unless the actuator is disconnected from the wastegate. So what ever the spring tension is set at is the factory boost setting.
