-   -   Suspension issue (https://www.vadriven.com/forums/tech-talk-9/suspension-issue-490252/)
91tegrsjg Sep 21, 2015 10:14 AM
Suspension issue
So last week I got ran off the off the road by what I assume was a drunk driver. Ended up hitting a curb pretty hard. it was obvious the alignment was out of whack. I just had the car aligned at Racewerks. The toe was off by a lot and the camber was off. Once the toe was adjusted the camber went to -2.22. Now it pulls really hard to the right. Dan assumes the strut is bent. There is no visible sign of damage. Does anyone have an idea? Oh and it is a 2011 GTI
Yardjass Sep 21, 2015 11:10 AM
Re: Suspension issue
Have you or anyone else gotten it up on a lift and looked at it? I think those are macpherson struts in the front so that would make sense. Only other thing I could think of is a fucked up bushing somewhere if you can't see any visible damage on the control arms.
91tegrsjg Sep 21, 2015 11:37 AM
yeah it was on the lift when we were looking at it
Fabrik8 Sep 21, 2015 02:38 PM
You likely bent the strut. You probably want to check the control arm as well, and the subframe mounts. Once it's aligned, a bent strut rod can turn and take a completely different position when you change direction in a turn, etc. Usually you can feel something shifting around when you turn right versus left, etc., as the strut rod rotates to a different equilibrium position with the change in load.
smilin dave Sep 21, 2015 02:42 PM
I personally would start disassembling the front of this car until I found the issue. I would hate to be behind you in a 62k lb truck when the suspension decided to have a major failure. This could happen tomorrow, I will be in the area in the am. Come on , REALLY? You really have to ask? Please take it apart until the offending part is found and replaced or become road pizza when it fails.
Warmest Regards
Dave
Yardjass Sep 21, 2015 05:10 PM
Yep, and make your fucking insurance pay for it all because fuck footing that bill.
91tegrsjg Sep 23, 2015 11:27 AM
well if the repair is less than my deductible, ill do it myself. the only problem is I have one working hand
award78 Sep 24, 2015 05:49 AM
I'd lend you a hand if I were closer:D
Hooch Sep 24, 2015 08:46 AM
You should lurk more and post less.
91tegrsjg Sep 24, 2015 12:50 PM
no offense, no clue who you are so I don't think I'd be letting a total stranger touch my car.
